Heatpump_energy out by factor of x10
I’ve finally installed the Level 3 Heat Pump Monitoring Bundle (emonHP) kit (yes don’t order it the day after the heat pump installation).
All is working fine but the heatpump_energy feed seems to be out by a factor of 10. For example when seen in home assistant. Is that expected?
For example from yesterday the value has increased by 300kwh.
