Hi. Complete newbie here so any input appreciated.
I have linked my Sontex supercal 531 bus output to a Mbus to USB connecter and connected to a raspberry pi running with the preloaded SD card. When I power on, it seems to get readings from the heatmeter as I get the following inputs:
However, after that, I don’t seem to get any updates. When I look at the log in emonhub, it just shows:
I have checked the baud rate on the meter and the address, which show as 2400 and 0 respectively on the heatmeter display. I have added the following to the config from others who have used this meter:
[[MBUS]]
    Type = EmonHubMBUSInterfacer
    [[[init_settings]]]
        device = /dev/ttyUSB0
        baud = 2400
    [[[runtimesettings]]]
        pubchannels = ToEmonCMS,
        read_interval = 10
        validate_checksum = False
        nodename = MBUS
        [[[[meters]]]]
            [[[[[heatmeter]]]]]
                address = 0
                type = sontex531
Would appreciate any direction to look to get this working ok. I will be adding in an SDM120 electric meter later today when my electrician installs it, so I want to connect that too.
Thanks for any direction
My config settings are …
[[SDM120]]
    [[[init_settings]]]
        device = /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0
        baud = 9600
        parity = none
        datatype = float
        read_interval = 10
        nodename = modbus
        [[[[meters]]]]
            [[[[[sdm120]]]]]
                address = 1
                registers = 0, 6, 12, 18, 30, 70, 72, 74, 76, 342
                names = V, I, P, VA, PF, FR, EI, EE, RI, TP
                precision = 2, 3, 1, 1, 3, 3, 3, 3, 3, 3
[[MBUS]]
    [[[init_settings]]]
        device = /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
        baud = 2400
        read_interval = 10
        nodename = mbus
        [[[[meters]]]]
            [[[[[sontex]]]]]
                address = 0
                type = standard
I have an SDM120 and Sontex 749.
One of the devices needs the ‘page’ moving so you get the correct data sent - it’s documented somewhere but I can’t find it or remember which device it applies to!
Found it - https://docs.openenergymonitor.org/emonhub/emonhub-interfacers.html#mbus-reader-for-electric-and-heat-meters
Implies the 531 doesn’t need this.
Just to check, is it M-Bus or Modbus - they are not the same!
There are threads elsewhere re the USB adapter and I think some have been troublesome. @glyn.hudson is I think the right person for this.
Can I also ask that you paste log output as pre-formatted text (Ctl-E) and not screen shots.
On the log, if you restart emonhub and post the initial output where the interfacer is setup, that will help.
Thanks for the replies.
The SDM120 module is working ok. Still no joy on the Sontex.
I had assumed it is only Mbus on the Supercal meter. It says M-bus on the terminals, hadn’t thought it could be Modbus?
Could be the adapter! Is there a way to check if it is working?
I measured across the terminals on the adapter - it shows 28v. Is that normal?
I had real problems connecting mbus but Trystan sorted me out. Use their mbus reader worked perfectly with my sontex449.
That is fine, not everyone understands there is a difference :slight_smile:
Yes I think OEM have found that some adapters work better than others.
I have solved it. Probably an amateur error. But had to change the config to USB1 for the mbus adapter. It’s been working all night by the looks of it!
[[MBUS]]
    [[[init_settings]]]
        device = /dev/ttyUSB1
Thanks for everyone’s input!
Yes it does tend to work when you are looking in the right place for the data :rofl: .
Glad it’s sorted.
Yep! I said it was amateur hour :grinning:
That’s one reason to use a device path that won’t change as /dev/ttyUSBnn potentially will.
