Heat pump calculation tools
New menu and link to source code
I’ve updated the collection of heat pump calculation tools that I’ve been building slowly over the last few years to have a menu system and link to the GitHub source code. This should improve navigation and provide a more connected experience.
Note: While some of these tools have been developed with testing on mobile, most are best viewed on a wider screen and need more work for a nice mobile experience.
New tool: Weather Compensation calculator
List of available tools:
Other tools
The following are developed by OpenEnergyMonitor (SAP.js and the ZCB model in collaboration with CarbonCoop and The Center for Alternative Technology) but are not integrated into this site:
  • HeatLoss.js
    An open source room by room heat loss calculator.
  • SAP.js
    An open source javascript implementation of the SAP 2012 monthly building energy model.
  • ZeroCarbonBritain energy model
    An open-source javascript implementation of the 10-year hourly cross sectoral UK energy model behind the ZeroCarbonBritain scenario.
Hi @TrystanLea,
Is there any mileage in adding a little tool for roomstat setback recovery time, as outlined in House Thermal Inertia and Roomstat Setback (some cautionary notes)? It seems to have been fairly well received…
Thanks Sarah, I will have a good read and see what I can add.
Another mini tool added, quickly enter K1, P+, K2 & K3 radiators, calculate both total rated output and heat output at lower flow temperatures. Radiator data based on fitting equations to the Stelrad radiator tables “Elite” range which I think is actually just standard rads.
https://openenergymonitor.org/tools/RadSchedule
The curve fitting of the stelrad tables is quite nice, if I might say so myself :joy:
  • The height component is 2nd order polynomial
  • The length component is linear
  • Yes all those decimal places did seem to be required!
calculate_rated_output: function(type, height, length) {
    var m = 0;
    var output = 0;
    if (type == "K1") {
        m = -0.000000454*Math.pow(height,2)+0.002017178*height-0.047435696;
        output = Math.round(m * length);
    else if (type == "P+") {
        m = -0.000000567*Math.pow(height,2)+0.002620013*height+0.040997375;
    else if (type == "K2") {
        m = -0.00000058*Math.pow(height,2)+0.00308043*height+0.14058005;
    else if (type == "K3") {
        m = -0.000000961*Math.pow(height,2)+0.004518773*height+0.1489;
    return output;
A tool when someone can enter the heatlose for each room and the radator lengths along with max possible height, that then calculates type/height combination for each possible flow temperature may be useful to many people. (Eg what can be easily done with existing pipework.)
