Heat losses measurement with temperature sensors
I’m looking for a solution for a thermal performance test with real measurements of internal temperature and energy consumption ( just WiFi temperature sensors).
What possible options have OEM to calculate heat demand without heat meter ?
To upload a CSV file is possible?
Hello Alex
You will need to measure or estimate heat input somehow to do this. E.g with gas meter readings and electricity meter readings if you have these ? What form of heating do you have?
You could do a weekly or monthly analysis, measure average internal temperature, average outside temperature, and estimate kWh of heat input from the heating system, measure kWh electricity consumption, estimate other gains such as body heat and solar gains. The heat loss coefficient is then total average heat input from all sources of heat/gain over e.g a week/month divided by the difference in temperature…
