Afternoon, after a year of tinkering Ive finally got round to fitting my Axioma e4 heat meter to the EmonPi2 as I had originally tried to integrate with a different meter! So the equipment was bought in singles, I have this afternoon plumbed in the Heat meter and trying to configure, I can seem to see the meter but can see its showing data on the meter it self, is this a set up issue that in need to tell the Pi what meter is fitted? Any advice is welcome.
Hello @RM1 it’s probably the MBUS address of the heat meter that’s not configured correctly. If you can email us with your installation postcode or/and order number to [email protected] I should be able to fix this for you remotely.
Email sent many thanks
