Hassio Hac install
Hi, I have had a hacs install connected to an openevse for a while now. However my openevse has changed ip address. where can i change the hassio ip address for the evse?
Looks like it’s “Settings \ Devices & Services \ OpenEVSE” then click on the three vertical dots to the right of Integrations and select Reconfigure. The hostname/IP is the second entry in the dialogue box that pops up. FWIW, I use a hostname, which works fine.
