I’m currently working on an outdoor energy monitoring terminal that uses a projected capacitive (PCAP) touchscreen for user interaction. The system is installed inside a metal enclosure and operates continuously in an outdoor environment.
During field testing, we occasionally encounter ghost touch (false touch) events that are difficult to reproduce consistently.
Typical symptoms include:
Random touch events without user interaction
Unstable touch response near the screen edges
Occasional touch failure after rain or high humidity
Better touch performance after the enclosure dries
Intermittent touch instability when nearby power electronics are active
Initially, I suspected the touch panel itself, but after comparing several systems, it seems that the problem is more related to overall system integration than the LCD or touch sensor.
Some possible factors I’m investigating include:
EMI generated by switching power supplies or charging modules
Grounding quality of the metal enclosure
Shielding effectiveness of the touch signal cable
Moisture changing the capacitance detected by the touch controller
Thermal expansion caused by direct sunlight
Condensation inside the display assembly
For those who have deployed outdoor HMI systems, EV charging stations, solar monitoring terminals or industrial dashboards, I’d like to hear your experience.
Have you encountered similar ghost touch issues?
Did improving grounding significantly reduce the problem?
Does optical bonding help in humid outdoor environments?
Are waterproof touch algorithms effective during rain?
Have you found certain touch controller solutions that perform better under strong EMI conditions?
I’m particularly interested in real-world deployment experience from systems that operate 24/7 rather than laboratory testing.
While researching this issue, I also found a technical article that summarizes many of the same topics, including EMI interference, grounding, waterproof touch algorithms, optical bonding and thermal management for outdoor PCAP displays. I thought it was a useful reference for understanding the system-level causes of false touch:
How to Prevent False Touch in Outdoor Kiosk Displays
interested to know whether the community has additional recommendations or best practices that have worked in long-term outdoor deployments.
