Has anyone been able to read circulator pump data with ESP Altherma?
I’ve got ESP Altherma connected to my Daikin monobloc but would love to see more data around the circulation pump load to see pump head. I know there is a plethora of datapoint with ESP Altherma, but I haven’t seen anything on the circulation pump or PWM. thx
is this sufficient for what your looking for ?
Thanks - I’ll have a go at adding that.
I added the water pressure, pump signal and pressure sensor data points from ESP Altherma, these are plotted below. For the pump signal I inverted the reading to show a %. Have you been able to work out what water pressure and pressure sensor are actually reading, I can’t make head nor tail!
