Hanging hardware, requiring a power cycle
I am running emonHub on a Pi3 with the RFM69 board connected to the GPIO. It’s been running with no problems for some time now, but I woke up this morning to find that emonHub was not transmitting any sensor updates. Visual inspection revealed that the red LED was lit on the RF card.
A full power cycle was required to recover. Any ideas on how to debug this? As a precaution I have enabled persistent journals, in case it happens again.
There is another thread about emonhub stopping (died) Emonhub died. Check the emonhub logs.
Are you running just emonhub (i.e. not the EmonSD)?
Thanks for the pointer.
emonHub is running on a Pi that is also running Docker for some other stuff, including a local MQTT server.
I’ve looked back at the logs produced around the time the updates stopped. The last successful packet is at 02:03:49. There’s no further log entries until I restart emonHub at 15:44. This has no effect, so I reboot at 15:48. Again, no effect so I power cycle and the log resumes at 15:51 and we start getting packets again. There is a brief hiatus as we wait for the mqtt server to become available but then all is well.
Here’s the filtered log
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    RFM2Pi     26090 NEW FRAME : OK 26 162 0 0 0 159 1 27 0 1 0 0 0 (-50)
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    RFM2Pi     26090 Timestamp : 1610676228.496683
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    RFM2Pi     26090 From Node : 26
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    RFM2Pi     26090    Values : [16.2, 0, 41.5, 2.7, 1]
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    RFM2Pi     26090      RSSI : -50
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    RFM2Pi     26090 Sent to channel(start)' : ToEmonCMS
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    RFM2Pi     26090 Sent to channel(end)' : ToEmonCMS
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emon/emonth8/temperature 16.2
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emon/emonth8/external temperature 0
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emon/emonth8/humidity 41.5
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emon/emonth8/battery 2.7
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emon/emonth8/pulsecount 1
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emon/emonth8/rssi -50
Jan 15 02:03:48 docker4 emonHub[536]: INFO     MQTT       Publishing 'node' formatted msg
Jan 15 02:03:48 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emonhub/rx/26/values 16.2,0,41.5,2.7,1,-50
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    RFM2Pi     26091 NEW FRAME : OK 25 188 0 0 0 186 1 28 0 1 0 0 0 (-37)
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    RFM2Pi     26091 Timestamp : 1610676229.306698
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    RFM2Pi     26091 From Node : 25
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    RFM2Pi     26091    Values : [18.8, 0, 44.2, 2.8000000000000003, 1]
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    RFM2Pi     26091      RSSI : -37
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    RFM2Pi     26091 Sent to channel(start)' : ToEmonCMS
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    RFM2Pi     26091 Sent to channel(end)' : ToEmonCMS
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emon/emonth7/temperature 18.8
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emon/emonth7/external temperature 0
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emon/emonth7/humidity 44.2
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emon/emonth7/battery 2.8000000000000003
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emon/emonth7/pulsecount 1
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emon/emonth7/rssi -37
Jan 15 02:03:49 docker4 emonHub[536]: INFO     MQTT       Publishing 'node' formatted msg
Jan 15 02:03:49 docker4 emonHub[536]: DEBUG    MQTT       Publishing: emonhub/rx/25/values 18.8,0,44.2,2.8000000000000003,1,-37
Jan 15 02:04:12 docker4 emonHub[536]: DEBUG    emoncmsorg Buffer size: 2
Jan 15 15:44:53 docker4 systemd[1]: Stopping emonHub data multiplexer...
Jan 15 15:44:53 docker4 emonHub[536]: DEBUG    MainThread Signal 15 received.
Jan 15 15:44:53 docker4 emonHub[536]: INFO     MainThread Exiting hub...
Jan 15 15:44:53 docker4 emonHub[536]: INFO     MainThread Exit completed
Jan 15 15:44:54 docker4 systemd[1]: Stopped emonHub data multiplexer.
Jan 15 15:44:54 docker4 systemd[1]: Starting emonHub data multiplexer...
Jan 15 15:44:54 docker4 systemd[1]: Started emonHub data multiplexer.
Jan 15 15:44:56 docker4 emonHub[15767]: INFO     MainThread EmonHub emonHub (emon-pi variant) v2.1.5
Jan 15 15:44:56 docker4 emonHub[15767]: INFO     MainThread Opening hub...
Jan 15 15:44:56 docker4 emonHub[15767]: INFO     MainThread Logging level set to DEBUG
Jan 15 15:44:56 docker4 emonHub[15767]: INFO     MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
Jan 15 15:44:56 docker4 emonHub[15767]: DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
Jan 15 15:44:58 docker4 emonHub[15767]: INFO     MainThread RFM2Pi device firmware version: [RF12demo.13]
Jan 15 15:44:58 docker4 emonHub[15767]: INFO     MainThread RFM2Pi device current settings:  E i5 g210 @ 433 MHz q1
Jan 15 15:44:58 docker4 emonHub[15767]: INFO     MainThread Setting RFM2Pi calibration: 230V (1p)
Jan 15 15:44:59 docker4 emonHub[15767]: DEBUG    MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
Jan 15 15:44:59 docker4 emonHub[15767]: DEBUG    MainThread Setting RFM2Pi subchannels: ['ToRFM12']
Jan 15 15:44:59 docker4 emonHub[15767]: INFO     MainThread Creating EmonHubMqttInterfacer 'MQTT'
Jan 15 15:44:59 docker4 emonHub[15767]: DEBUG    RFM2Pi     acknowledged command: > 1p
Jan 15 15:44:59 docker4 emonHub[15767]: DEBUG    MainThread Setting MQTT pubchannels: ['ToRFM12']
Jan 15 15:44:59 docker4 emonHub[15767]: DEBUG    MainThread Setting MQTT subchannels: ['ToEmonCMS']
Jan 15 15:44:59 docker4 emonHub[15767]: INFO     MainThread Setting MQTT node_format_enable: 1
Jan 15 15:44:59 docker4 emonHub[15767]: INFO     MainThread Setting MQTT nodevar_format_enable: 1
Jan 15 15:44:59 docker4 emonHub[15767]: INFO     MainThread Setting MQTT nodevar_format_basetopic: emon/
Jan 15 15:44:59 docker4 emonHub[15767]: INFO     MainThread Setting MQTT node_JSON_enable: 0
Jan 15 15:44:59 docker4 emonHub[15767]: INFO     MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
Jan 15 15:44:59 docker4 emonHub[15767]: DEBUG    MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
Jan 15 15:44:59 docker4 emonHub[15767]: DEBUG    MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
Jan 15 15:44:59 docker4 emonHub[15767]: WARNING  MainThread Setting emoncmsorg apikey: obscured
Jan 15 15:44:59 docker4 emonHub[15767]: INFO     MainThread Setting emoncmsorg url: https://emoncms.org
Jan 15 15:44:59 docker4 emonHub[15767]: INFO     MainThread Setting emoncmsorg senddata: 1
Jan 15 15:44:59 docker4 emonHub[15767]: INFO     MainThread Setting emoncmsorg sendstatus: 1
Jan 15 15:44:59 docker4 emonHub[15767]: DEBUG    RFM2Pi     acknowledged command: <nn> i     - set node ID (standard node ids are 1..30)
Jan 15 15:44:59 docker4 emonHub[15767]: DEBUG    RFM2Pi     acknowledged command: <n> b      - set MHz band (4 = 433, 8 = 868, 9 = 915)
Jan 15 15:45:00 docker4 emonHub[15767]: DEBUG    RFM2Pi     acknowledged command: <nnnn> o   - change frequency offset within the band (default 1600)
Jan 15 15:45:00 docker4 emonHub[15767]: DEBUG    RFM2Pi     acknowledged command: <nnn> g    - set network group (RFM12 only allows 212, 0 = any)
Jan 15 15:45:00 docker4 emonHub[15767]: DEBUG    RFM2Pi     acknowledged command: <n> c      - set collect mode (advanced, normally 0)
Jan 15 15:45:00 docker4 emonHub[15767]: DEBUG    RFM2Pi     acknowledged command: ...,<nn> a - send data packet to node <nn>, request ack
Jan 15 15:45:00 docker4 emonHub[15767]: DEBUG    RFM2Pi     acknowledged command: ...,<nn> s - send data packet to node <nn>, no ack
Jan 15 15:45:00 docker4 emonHub[15767]: DEBUG    RFM2Pi     acknowledged command: <n> q      - set quiet mode (1 = don't report bad packets)
Jan 15 15:45:00 docker4 emonHub[15767]: DEBUG    RFM2Pi     acknowledged command: <n> x      - set reporting format (0: decimal, 1: hex, 2: hex+ascii)
Jan 15 15:45:01 docker4 emonHub[15767]: DEBUG    RFM2Pi     acknowledged command: <hchi>,<hclo>,<addr>,<cmd> f     - FS20 command (868 MHz)
Jan 15 15:45:01 docker4 emonHub[15767]: DEBUG    RFM2Pi     acknowledged command: <addr>,<dev>,<on> k              - KAKU command (433 MHz)
Jan 15 15:45:01 docker4 emonHub[15767]: DEBUG    RFM2Pi     device settings updated: E i5 g210 @ 433 MHz q1
Jan 15 15:48:19 docker4 systemd[1]: Starting emonHub data multiplexer...
Jan 15 15:48:19 docker4 systemd[1]: Started emonHub data multiplexer.
Jan 15 15:48:24 docker4 emonHub[538]: INFO     MainThread EmonHub emonHub (emon-pi variant) v2.1.5
Jan 15 15:48:24 docker4 emonHub[538]: INFO     MainThread Opening hub...
Jan 15 15:48:24 docker4 emonHub[538]: INFO     MainThread Logging level set to DEBUG
Jan 15 15:48:24 docker4 emonHub[538]: INFO     MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
Jan 15 15:48:24 docker4 emonHub[538]: DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
Jan 15 15:48:26 docker4 emonHub[538]: INFO     MainThread RFM2Pi device firmware version: [RF12demo.13]
Jan 15 15:48:26 docker4 emonHub[538]: INFO     MainThread RFM2Pi device current settings:  E i5 g210 @ 433 MHz q1
Jan 15 15:48:26 docker4 emonHub[538]: INFO     MainThread Setting RFM2Pi calibration: 230V (1p)
Jan 15 15:48:27 docker4 emonHub[538]: DEBUG    MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
Jan 15 15:48:27 docker4 emonHub[538]: DEBUG    MainThread Setting RFM2Pi subchannels: ['ToRFM12']
Jan 15 15:48:27 docker4 emonHub[538]: INFO     MainThread Creating EmonHubMqttInterfacer 'MQTT'
Jan 15 15:48:27 docker4 emonHub[538]: DEBUG    RFM2Pi     acknowledged command: > 1p
Jan 15 15:48:27 docker4 emonHub[538]: DEBUG    MainThread Setting MQTT pubchannels: ['ToRFM12']
Jan 15 15:48:27 docker4 emonHub[538]: DEBUG    MainThread Setting MQTT subchannels: ['ToEmonCMS']
Jan 15 15:48:27 docker4 emonHub[538]: INFO     MainThread Setting MQTT node_format_enable: 1
Jan 15 15:48:27 docker4 emonHub[538]: INFO     MainThread Setting MQTT nodevar_format_enable: 1
Jan 15 15:48:27 docker4 emonHub[538]: INFO     MainThread Setting MQTT nodevar_format_basetopic: emon/
Jan 15 15:48:27 docker4 emonHub[538]: INFO     MainThread Setting MQTT node_JSON_enable: 0
Jan 15 15:48:27 docker4 emonHub[538]: INFO     MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
Jan 15 15:48:27 docker4 emonHub[538]: DEBUG    MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
Jan 15 15:48:27 docker4 emonHub[538]: DEBUG    MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
Jan 15 15:48:27 docker4 emonHub[538]: WARNING  MainThread Setting emoncmsorg apikey: obscured
Jan 15 15:48:27 docker4 emonHub[538]: INFO     MainThread Setting emoncmsorg url: https://emoncms.org
Jan 15 15:48:27 docker4 emonHub[538]: INFO     MainThread Setting emoncmsorg senddata: 1
Jan 15 15:48:27 docker4 emonHub[538]: INFO     MainThread Setting emoncmsorg sendstatus: 1
Jan 15 15:48:27 docker4 emonHub[538]: DEBUG    RFM2Pi     acknowledged command: <nn> i     - set node ID (standard node ids are 1..30)
Jan 15 15:48:27 docker4 emonHub[538]: DEBUG    RFM2Pi     acknowledged command: <n> b      - set MHz band (4 = 433, 8 = 868, 9 = 915)
Jan 15 15:48:27 docker4 emonHub[538]: DEBUG    RFM2Pi     acknowledged command: <nnnn> o   - change frequency offset within the band (default 1600)
Jan 15 15:48:28 docker4 emonHub[538]: DEBUG    RFM2Pi     acknowledged command: <nnn> g    - set network group (RFM12 only allows 212, 0 = any)
Jan 15 15:48:28 docker4 emonHub[538]: DEBUG    RFM2Pi     acknowledged command: <n> c      - set collect mode (advanced, normally 0)
Jan 15 15:48:28 docker4 emonHub[538]: DEBUG    RFM2Pi     acknowledged command: ...,<nn> a - send data packet to node <nn>, request ack
Jan 15 15:48:28 docker4 emonHub[538]: DEBUG    RFM2Pi     acknowledged command: ...,<nn> s - send data packet to node <nn>, no ack
Jan 15 15:48:28 docker4 emonHub[538]: DEBUG    RFM2Pi     acknowledged command: <n> q      - set quiet mode (1 = don't report bad packets)
Jan 15 15:48:28 docker4 emonHub[538]: DEBUG    RFM2Pi     acknowledged command: <n> x      - set reporting format (0: decimal, 1: hex, 2: hex+ascii)
Jan 15 15:48:29 docker4 emonHub[538]: DEBUG    RFM2Pi     acknowledged command: <hchi>,<hclo>,<addr>,<cmd> f     - FS20 command (868 MHz)
Jan 15 15:48:29 docker4 emonHub[538]: DEBUG    RFM2Pi     acknowledged command: <addr>,<dev>,<on> k              - KAKU command (433 MHz)
Jan 15 15:48:29 docker4 emonHub[538]: DEBUG    RFM2Pi     device settings updated: E i5 g210 @ 433 MHz q1
Jan 15 15:51:41 docker4 systemd[1]: Starting emonHub data multiplexer...
Jan 15 15:51:41 docker4 systemd[1]: Started emonHub data multiplexer.
Jan 15 15:51:46 docker4 emonHub[544]: INFO     MainThread EmonHub emonHub (emon-pi variant) v2.1.5
Jan 15 15:51:46 docker4 emonHub[544]: INFO     MainThread Opening hub...
Jan 15 15:51:46 docker4 emonHub[544]: INFO     MainThread Logging level set to DEBUG
Jan 15 15:51:46 docker4 emonHub[544]: INFO     MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
Jan 15 15:51:46 docker4 emonHub[544]: DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
Jan 15 15:51:48 docker4 emonHub[544]: INFO     MainThread RFM2Pi device firmware version: [RF12demo.13]
Jan 15 15:51:48 docker4 emonHub[544]: INFO     MainThread RFM2Pi device current settings:  E i5 g210 @ 433 MHz q1
Jan 15 15:51:48 docker4 emonHub[544]: INFO     MainThread Setting RFM2Pi calibration: 230V (1p)
Jan 15 15:51:49 docker4 emonHub[544]: DEBUG    MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
Jan 15 15:51:49 docker4 emonHub[544]: DEBUG    MainThread Setting RFM2Pi subchannels: ['ToRFM12']
Jan 15 15:51:49 docker4 emonHub[544]: INFO     MainThread Creating EmonHubMqttInterfacer 'MQTT'
Jan 15 15:51:49 docker4 emonHub[544]: DEBUG    RFM2Pi     acknowledged command: > 1p
Jan 15 15:51:49 docker4 emonHub[544]: DEBUG    MainThread Setting MQTT pubchannels: ['ToRFM12']
Jan 15 15:51:49 docker4 emonHub[544]: DEBUG    MainThread Setting MQTT subchannels: ['ToEmonCMS']
Jan 15 15:51:49 docker4 emonHub[544]: INFO     MainThread Setting MQTT node_format_enable: 1
Jan 15 15:51:49 docker4 emonHub[544]: INFO     MainThread Setting MQTT nodevar_format_enable: 1
Jan 15 15:51:49 docker4 emonHub[544]: INFO     MainThread Setting MQTT nodevar_format_basetopic: emon/
Jan 15 15:51:49 docker4 emonHub[544]: INFO     MainThread Setting MQTT node_JSON_enable: 0
Jan 15 15:51:49 docker4 emonHub[544]: INFO     MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
Jan 15 15:51:49 docker4 emonHub[544]: DEBUG    MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
Jan 15 15:51:49 docker4 emonHub[544]: DEBUG    MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
Jan 15 15:51:49 docker4 emonHub[544]: WARNING  MainThread Setting emoncmsorg apikey: obscured
Jan 15 15:51:49 docker4 emonHub[544]: INFO     MainThread Setting emoncmsorg url: https://emoncms.org
Jan 15 15:51:49 docker4 emonHub[544]: INFO     MainThread Setting emoncmsorg senddata: 1
Jan 15 15:51:49 docker4 emonHub[544]: INFO     MainThread Setting emoncmsorg sendstatus: 1
Jan 15 15:51:50 docker4 emonHub[544]: DEBUG    RFM2Pi     acknowledged command: <nn> i     - set node ID (standard node ids are 1..30)
Jan 15 15:51:50 docker4 emonHub[544]: DEBUG    RFM2Pi     acknowledged command: <n> b      - set MHz band (4 = 433, 8 = 868, 9 = 915)
Jan 15 15:51:50 docker4 emonHub[544]: DEBUG    RFM2Pi     acknowledged command: <nnnn> o   - change frequency offset within the band (default 1600)
Jan 15 15:51:50 docker4 emonHub[544]: DEBUG    RFM2Pi     acknowledged command: <nnn> g    - set network group (RFM12 only allows 212, 0 = any)
Jan 15 15:51:50 docker4 emonHub[544]: DEBUG    RFM2Pi     acknowledged command: <n> c      - set collect mode (advanced, normally 0)
Jan 15 15:51:50 docker4 emonHub[544]: DEBUG    RFM2Pi     acknowledged command: ...,<nn> a - send data packet to node <nn>, request ack
Jan 15 15:51:50 docker4 emonHub[544]: DEBUG    RFM2Pi     acknowledged command: ...,<nn> s - send data packet to node <nn>, no ack
Jan 15 15:51:51 docker4 emonHub[544]: DEBUG    RFM2Pi     acknowledged command: <n> q      - set quiet mode (1 = don't report bad packets)
Jan 15 15:51:51 docker4 emonHub[544]: DEBUG    RFM2Pi     acknowledged command: <n> x      - set reporting format (0: decimal, 1: hex, 2: hex+ascii)
Jan 15 15:51:51 docker4 emonHub[544]: DEBUG    RFM2Pi     acknowledged command: <hchi>,<hclo>,<addr>,<cmd> f     - FS20 command (868 MHz)
Jan 15 15:51:51 docker4 emonHub[544]: DEBUG    RFM2Pi     acknowledged command: <addr>,<dev>,<on> k              - KAKU command (433 MHz)
Jan 15 15:51:51 docker4 emonHub[544]: DEBUG    RFM2Pi     device settings updated: E i5 g210 @ 433 MHz q1
Jan 15 15:51:58 docker4 emonHub[544]: DEBUG    RFM2Pi     7 NEW FRAME : OK 26 4 1 0 0 132 1 27 0 1 0 0 0 (-57)
Jan 15 15:51:58 docker4 emonHub[544]: DEBUG    RFM2Pi     7 Timestamp : 1610725918.448843
Jan 15 15:51:58 docker4 emonHub[544]: DEBUG    RFM2Pi     7 From Node : 26
Jan 15 15:51:58 docker4 emonHub[544]: DEBUG    RFM2Pi     7    Values : [26, 0, 38.800000000000004, 2.7, 1]
Jan 15 15:51:58 docker4 emonHub[544]: DEBUG    RFM2Pi     7      RSSI : -57
Jan 15 15:51:58 docker4 emonHub[544]: DEBUG    RFM2Pi     7 Sent to channel(start)' : ToEmonCMS
Jan 15 15:51:58 docker4 emonHub[544]: DEBUG    RFM2Pi     7 Sent to channel(end)' : ToEmonCMS
Jan 15 15:51:58 docker4 emonHub[544]: INFO     MQTT       Connecting to MQTT Server
Jan 15 15:53:08 docker4 emonHub[544]: INFO     MQTT       connection status: Connection successful
Jan 15 15:53:08 docker4 emonHub[544]: DEBUG    MQTT       CONACK => Return code: 0
Jan 15 15:53:15 docker4 emonHub[544]: INFO     MQTT       on_subscribe
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    RFM2Pi     12 NEW FRAME : OK 24 196 0 32 0 177 1 28 0 1 0 0 0 (-62)
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    RFM2Pi     12 Timestamp : 1610725997.525853
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    RFM2Pi     12 From Node : 24
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    RFM2Pi     12    Values : [19.6, 3.2, 43.300000000000004, 2.8000000000000003, 1]
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    RFM2Pi     12      RSSI : -62
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    RFM2Pi     12 Sent to channel(start)' : ToEmonCMS
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    RFM2Pi     12 Sent to channel(end)' : ToEmonCMS
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth6/temperature 19.6
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth6/external temperature 3.2
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth6/humidity 43.300000000000004
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth6/battery 2.8000000000000003
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth6/pulsecount 1
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth6/rssi -62
Jan 15 15:53:17 docker4 emonHub[544]: INFO     MQTT       Publishing 'node' formatted msg
Jan 15 15:53:17 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emonhub/rx/24/values 19.6,3.2,43.300000000000004,2.8000000000000003,1,-62
Jan 15 15:53:24 docker4 emonHub[544]: DEBUG    RFM2Pi     13 NEW FRAME : OK 25 200 0 0 0 189 1 28 0 1 0 0 0 (-37)
Jan 15 15:53:24 docker4 emonHub[544]: DEBUG    RFM2Pi     13 Timestamp : 1610726004.969542
Jan 15 15:53:24 docker4 emonHub[544]: DEBUG    RFM2Pi     13 From Node : 25
Jan 15 15:53:24 docker4 emonHub[544]: DEBUG    RFM2Pi     13    Values : [20, 0, 44.5, 2.8000000000000003, 1]
Jan 15 15:53:24 docker4 emonHub[544]: DEBUG    RFM2Pi     13      RSSI : -37
Jan 15 15:53:24 docker4 emonHub[544]: DEBUG    RFM2Pi     13 Sent to channel(start)' : ToEmonCMS
Jan 15 15:53:24 docker4 emonHub[544]: DEBUG    RFM2Pi     13 Sent to channel(end)' : ToEmonCMS
Jan 15 15:53:25 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth7/temperature 20
Jan 15 15:53:25 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth7/external temperature 0
Jan 15 15:53:25 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth7/humidity 44.5
Jan 15 15:53:25 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth7/battery 2.8000000000000003
Jan 15 15:53:25 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth7/pulsecount 1
Jan 15 15:53:25 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth7/rssi -37
Jan 15 15:53:25 docker4 emonHub[544]: INFO     MQTT       Publishing 'node' formatted msg
Jan 15 15:53:25 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emonhub/rx/25/values 20,0,44.5,2.8000000000000003,1,-37
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    RFM2Pi     14 NEW FRAME : OK 23 187 0 0 0 226 1 29 0 1 0 0 0 (-27)
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    RFM2Pi     14 Timestamp : 1610726006.299201
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    RFM2Pi     14 From Node : 23
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    RFM2Pi     14    Values : [18.7, 0, 48.2, 2.9000000000000004, 1]
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    RFM2Pi     14      RSSI : -27
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    RFM2Pi     14 Sent to channel(start)' : ToEmonCMS
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    RFM2Pi     14 Sent to channel(end)' : ToEmonCMS
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth5/temperature 18.7
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth5/external temperature 0
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth5/humidity 48.2
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth5/battery 2.9000000000000004
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth5/pulsecount 1
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emon/emonth5/rssi -27
Jan 15 15:53:26 docker4 emonHub[544]: INFO     MQTT       Publishing 'node' formatted msg
Jan 15 15:53:26 docker4 emonHub[544]: DEBUG    MQTT       Publishing: emonhub/rx/23/values 18.7,0,48.2,2.9000000000000004,1,-27
Jan 15 15:53:28 docker4 emonHub[544]: DEBUG    emoncmsorg Buffer size: 3
Sadly yes, this has been seen before but the reason remains unknown (and rare).
The most likely reason is Network issues.
OK, thanks, Brian.
Next time it happens, I’ll try the reset script mentioned in the other thread. If this is successful, I can build an auto-responder that kicks in when data stops flowing.
