Any Haier experts here?
I have a Haier Hydro All-in-One 8kW heat pump (HU102F20AHYA) and would like to send a “heating ON” signal to my underfloor wiring strip.
This unit has a Heating/Cooling changeover output signal, but since I am not using cooling, I have disabled it in the pump controller. Because of this, I cannot use that specific signal.
Looking at the remaining pins, I see a “Floor Valve” state. This would be perfect to wire into a relay with a dry contact switch. However, I don’t know how this signal actually behaves. Does it change state depending on the compressor function, or is it always ON whenever the pump is in winter mode?
The last option I am considering is using a Zigbee relay with a dry contact output to block the underfloor wiring strip when heating is turned off.
Just to explain why I need this: without it, any room thermostat could trigger the zone actuators to open even when the pump is strictly in DHW (Domestic Hot Water) mode.
I have studied all the technical manuals I could find and sent several emails to Haier support, but they never replied. ![]()
I would be grateful for any assistance!
