I installed my Openevse a month ago, and I’ve charged successfully twice since then. After the last charge, I updated the wifi module to 4.1.7 since I’m in version 8.2.0 EU.
Yesterday night I scheduled the charge from 2am to 6am (my cheapest rate) and this morning the car wasn’t charged .
Now, I’m trying to charge manually (no scheduled) but every time I connect the plug to the car the charger is saying GFCI Fault, service required.
I’ve tried to disable the GFCI self-check (I’m in Europe so RCD is in place) but no luck…
Any suggestion? might be the wifi firmware upgrade the problem? I didn’t restore the old version I had 4.1.3, but not sure if that might be the case.
Thank you in advance and any help is appreciated.
