Hi, I’ve got the above message today having finally got round to running an Ethernet cable to the unit yesterday.
When opening the case the brown live wire fell out of connection block that connects to the front type2 socket. It had pulled clean out of the crimp, so I removed the crimp and reattached. It feels like it’s in firm now.
It’s an emon evse FW 8.2.0t2
WiFi fw 4.13
I assumed I had disturbed on of the connections in opening the case but have checked them all and looks ok.
Reading on another post it suggested turning off gfci if via rcd, it is, so I tried and it still aborts the charge straight away and red fault message on LCD.
Any help much appreciated.
