Hello guys,
We have developed system AMR in which we are getting leading counting problem. we have removed all the noise we did code for only calculating valid pulse but still we are getting more pulses in counting.
In one day we are getting almost 100 pulses extra for around 3 kilowatt load.
Please suggest solution if you have.
thank you.
There’s not enough real information there about your system and what you’re trying to do for anyone to provide any real help. See the FAQ page:
The short answer to interference problems, if indeed that is what you have, is to trace the source, or more likely sources, of the interference and eliminate it at source. That is usually much more effective, though often harder, than trying to keep it out or ameliorate its effects.
