I can mess about with scripts but writing code is not my cuppa tea. would anyone be interested in helping I am not even sure we would get the right data from the inverter.
They would need to be a few steps
Check the connection from the inverter
Check the data is correct
Get the data into emon
I could offer my time, a small payment or some hardware.
From reading GitHub - dickontoo/inverter: SolaX PV Inverter data dumper
the inverter would try and send the data to a specified ip address every 300 seconds.
I can login to the webpage for the inverter and set the ip address and port of the emonpi but I am not sure how to get the emompi to accept the data and process it.
You would need an intermediary parser to convert the data to the correct format that emoncms can accept. On git hub they mentioned that inverter can write data to log.pl file. If you can get the inverter to write data to that file, then it would be very easy to write a parser that can read data from log.pl and post to emoncms
