Hello,
I have a geiger counter esp32 which is outputting a telnet stream as follows:
CPS, 1, CPM, 13, uSv/hr, 0.07, SLOW
CPS, 0, CPM, 13, uSv/hr, 0.07, SLOW
I would like to add this data to my emoncms (pi) which is already receiving data from several mqtt sensors and a weather station (VP2+) running weewx. I’m not a programmer and am not sure how to do this. The esp32 also sends out an http stream on port 81. Much appreciated if anyone could help.
Cheers,
Bob
Node-RED has a couple of Telnet client nodes so if that will read the stream, converting that to a format to send to Emoncms, should be reasonably easy.
Thanks for the reply, Brian. I have node-red working for some mqtt sensors and have tried the telnet module nodes to no avail. I tried “telnet request” and “telnet read” to 192.168.1.100:23 but for some reason I’m not getting any connection to the emonpi from the esp32. If I use a terminal screen from the emonpi the telnet connects immediately with no id/password. Once I get a connection, I may be able to figure this out. Cheers.
Bob
