Hey guys - hoping an emonSD and file system guru can help me, although not strictly related to OEM!
Trying to side load tuya-convert for some home automation work but have hit a snag with a pip install. Keeping getting a free space error when one of the components tries to install:
Collecting pycryptodomex
Using cached https://files.pythonhosted.org/packages/f5/79/9d9206688385d1e7a5ff925e7aab1d685636256e34a409037aa7adbbe611/pycryptodomex-3.9.8.tar.gz
Could not install packages due to an EnvironmentError: [Errno 28] No space left on device
I have tried clearly temp directories and pruning/clearing unused packages, but I am assuming this is a temp directory issue as I have plenty of space on the SD:
pi@emonpi:/tmp $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 4.0G 2.1G 1.8G 55% /
devtmpfs 484M 0 484M 0% /dev
tmpfs 488M 0 488M 0% /dev/shm
tmpfs 488M 6.6M 482M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 488M 0 488M 0% /sys/fs/cgroup
tmpfs 1.0M 0 1.0M 0% /var/lib/php/sessions
tmpfs 1.0M 0 1.0M 0% /var/tmp
tmpfs 30M 0 30M 0% /tmp
/dev/mmcblk0p3 10G 681M 8.9G 8% /var/opt/emoncms
/dev/mmcblk0p1 253M 52M 201M 21% /boot
log2ram 50M 1.6M 49M 4% /var/log
tmpfs 98M 0 98M 0% /run/user/1000
Is there a remapping of temp or a command that would allow me to get this package installed?
Cheers.
