Hi
Raspberry Pi 3 Model B+ Rev 1.3 - 1 GB running latest emonCMS
Looking in administration I noticed a recurring error.
LAST ENTRIES ON THE LOG FILE
2019-03-19 14:27:49.207|ERROR|feedwriter.php|Starting feedwriter script
2019-03-19 15:27:19.129|ERROR|feedwriter.php|Starting feedwriter script
2019-03-19 16:27:21.418|ERROR|feedwriter.php|Starting feedwriter script
2019-03-19 17:27:44.007|ERROR|feedwriter.php|Starting feedwriter script
2019-03-19 18:00:49.421|WARN|emoncms_mqtt.php|Not connected, retrying connection
2019-03-19 18:00:49.437|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2019-03-19 18:27:54.288|ERROR|feedwriter.php|Starting feedwriter script
2019-03-19 19:27:51.058|ERROR|feedwriter.php|Starting feedwriter script
2019-03-19 20:27:50.095|ERROR|feedwriter.php|Starting feedwriter script
2019-03-19 21:27:46.463|ERROR|feedwriter.php|Starting feedwriter script
2019-03-19 22:27:44.497|ERROR|feedwriter.php|Starting feedwriter script
2019-03-19 23:27:44.479|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 00:25:26.230|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 01:25:26.141|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 02:25:25.952|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 03:25:26.060|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 04:25:26.130|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 05:25:26.131|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 06:25:26.079|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 07:25:26.219|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 08:25:26.247|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 09:25:26.259|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 10:27:54.371|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 11:28:14.156|ERROR|feedwriter.php|Starting feedwriter script
2019-03-20 12:28:17.776|ERROR|feedwriter.php|Starting fe
Emoncms is fully up to date. Is this something that needs attention?
Server Information
Server Information
Services | ||
emonhub | Active Running | |
emoncms_mqtt | Active Running | |
feedwriter | Active Running - sleep 60s | |
service-runner | Active Running | |
emonPiLCD | Active Exited | |
redis-server | Active Running | |
mosquitto | Inactive Dead | |
Emoncms | Version | low-write 9.9.8 |
Modules | Administration : App v1.2.1 : Backup v1.1.6 : EmonHub Config v1.1.0 : Dashboard v1.3.3 : demandshaper : Device v1.2.1 : EventProcesses : Feed : Graph v1.2.3 : Input : Postprocess v1.0.0 : CoreProcess : Schedule : Network Setup v1.0.0 : sync : Time : User : Visualisation : WiFi v1.3.1 | |
Git | URL: GitHub - emoncms/emoncms: Web-app for processing, logging and visualising energy, temperature and other environmental data : Branch: * stable : Describe: 9.9.8-4-gd0db7a57 | |
Server | OS | Linux 4.14.71-v7+ |
Host | emonpi : emonpi : (192.168.1.22) | |
Date | 2019-03-21 09:29:39 UTC | |
Uptime | 09:29:39 up 2 days, 23:48, 0 users, load average: 0.26, 0.18, 0.11 | |
HTTP | Server | Apache/2.4.25 (Raspbian) HTTP/1.1 CGI/1.1 80 |
MySQL | Version | 5.5.5-10.1.23-MariaDB-9+deb9u1 |
Host | 127.0.0.1 (127.0.0.1) | |
Date | 2019-03-21 09:29:39 (UTC 00:00) | |
Stats | Uptime: 258477 Threads: 4 Questions: 1097255 Slow queries: 0 Opens: 53 Flush tables: 1 Open tables: 47 Queries per second avg: 4.245 | |
Redis | Version | 3.2.6 |
Host | localhost:6379 (127.0.0.1) | |
Size | ||
Uptime | 2 days | |
MQTT Server | Version | Mosquitto 1.4.10 |
Host | 192.168.1.28:2082 (192.168.1.28) | |
Pi | Model | Raspberry Pi 3 Model B+ Rev 1.3 - 1 GB (Sony UK) |
SoC | Broadcom BCM2835 | |
Serial num. | 4F2878CB | |
Temperature | CPU: 47.24°C - GPU: 47.2’C | |
Release | emonSD-30Oct18 | |
Memory | RAM | Used: 30.82% Total: 976.74 MB Used: 301 MB Free: 675.74 MB |
Swap | Used: 99.93% Total: 100 MB Used: 99.93 MB Free: 68 KB | |
Disk | Mount | Stats |
/ | Used: 44.70% Total: 3.81 GB Used: 1.71 GB Free: 1.93 GB | |
/boot | Used: 51.69% Total: 42.52 MB Used: 21.98 MB Free: 20.54 MB | |
/home/pi/data | Used: 8.10% Total: 25.4 GB Used: 2.06 GB Free: 22.05 GB | |
PHP | Version | 7.0.30-0+deb9u1 (Zend Version 3.0.0) |
Modules | apache2handler : calendar v7.0.30-0+deb9u1 : Core v7.0.30-0+deb9u1 : ctype v7.0.30-0+deb9u1 : curl v7.0.30-0+deb9u1 : date v7.0.30-0+deb9u1 : dom v20031129 : exif v7.0.30-0+deb9u1 : fileinfo v1.0.5 : filter v7.0.30-0+deb9u1 : ftp v7.0.30-0+deb9u1 : gd v7.0.30-0+deb9u1 : gettext v7.0.30-0+deb9u1 : hash v1.0 : iconv v7.0.30-0+deb9u1 : igbinary v2.0.1 : json v1.4.0 : libxml v7.0.30-0+deb9u1 : mbstring v7.0.30-0+deb9u1 : mcrypt v7.0.30-0+deb9u1 : mosquitto v0.4.0 : mysqli v7.0.30-0+deb9u1 : mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $ : openssl v7.0.30-0+deb9u1 : pcre v7.0.30-0+deb9u1 : PDO v7.0.30-0+deb9u1 : pdo_mysql v7.0.30-0+deb9u1 : Phar v2.0.2 : posix v7.0.30-0+deb9u1 : readline v7.0.30-0+deb9u1 : redis v4.1.1 : Reflection v7.0.30-0+deb9u1 : session v7.0.30-0+deb9u1 : shmop v7.0.30-0+deb9u1 : SimpleXML v7.0.30-0+deb9u1 : sockets v7.0.30-0+deb9u1 : SPL v7.0.30-0+deb9u1 : standard v7.0.30-0+deb9u1 : sysvmsg v7.0.30-0+deb9u1 : sysvsem v7.0.30-0+deb9u1 : sysvshm v7.0.30-0+deb9u1 : tokenizer v7.0.30-0+deb9u1 : wddx v7.0.30-0+deb9u1 : xml v7.0.30-0+deb9u1 : xmlreader v7.0.30-0+deb9u1 : xmlwriter v7.0.30-0+deb9u1 : xsl v7.0.30-0+deb9u1 : Zend OPcache v7.0.30-0+deb9u1 : zlib v7.0.30-0+deb9u1 |
Client Information
HTTP | Browser | Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.121 Safari/537.36 |
Screen | Resolution | 1920 x 1080 |
Window | Size | 1528 x 927 |
Edit
I have just realised what might be causing this. I recently had a problem that caused lost data. As a temporary measure I am taking backups every hour. I have just reverted to daily backups and will check again tomorrow about the same time.
