Feedwriter not writing
Hopefully this is the right place for this as I am running emonSD.
System is up to date via the inbuilt update process. I’ve today changed the SD card to a new industrial spec one. I tried downloading the latest emonSD image (Feb-24) and flashing it to the SD but my old emonPi 1 did not seem to want to boot from that (and I left it plenty long!), so in the end I used dd to clone the old card directly. So it is based on the Oct-19 image but up to date.
The monitoring side works, I’m getting all the readings I expect from the CT clamps and the emonTX. But the readings don’t seem to be getting committed to disk.
The Feedwriter service is running but just has an ever increasing pile of ‘points pending write’.
This isn’t a huge problem for me as I use the emonPi as a means of getting the power data into Home Assistant where it is stored, but it niggles me that it’s not working when it should and I expect if I let the queue just grow and grow eventually something will break.
There is nothing obvious in any of the logs I can see that might explain it. Any ideas on where to look next?
Okay, I am an idiot.
Nothing is wrong, everything is working as expected. Feedwriter only writes to disk every 300s so points build up in that interval and then get flushed. It even says so right there in the status summary (sleeping 300s)!
Consider this an object lesson in thinking before you post :stuck_out_tongue:
