I could no access my dashboard (localhost) today, node-red reported for all Feeds: warning: "Error: connect ETIMEDOUT 127.0.0.1:80".
After some analysis, I was able to determine that the feedwriter was disabled.
After several attempts to get the feedwriter.service to run, I had the error messages:
`Dez 15 16:04:01 emonpi5 feedwriter[24016]: PHP Fatal error: Uncaught mysqli_sql_exception: The table 'feed_174' is full in /var/www/emoncms/Modules/feed/engine/MysqlTimeSeries.php:671
Dez 15 16:04:01 emonpi5 feedwriter[24016]: Stack trace:
Dez 15 16:04:01 emonpi5 feedwriter[24016]: #0 /var/www/emoncms/Modules/feed/engine/MysqlTimeSeries.php(671): mysqli->query()
Dez 15 16:04:01 emonpi5 feedwriter[24016]: #1 /var/www/emoncms/Modules/feed/engine/RedisBuffer.php(193): MysqlTimeSeries->post_bulk_save()
Dez 15 16:04:01 emonpi5 feedwriter[24016]: #2 /var/www/emoncms/Modules/feed/engine/RedisBuffer.php(151): RedisBuffer->process_feed_buffer()
Dez 15 16:04:01 emonpi5 feedwriter[24016]: #3 /var/www/emoncms/scripts/feedwriter.php(62): RedisBuffer->process_buffers()
Dez 15 16:04:01 emonpi5 feedwriter[24016]: #4 {main}
Dez 15 16:04:01 emonpi5 feedwriter[24016]: thrown in /var/www/emoncms/Modules/feed/engine/MysqlTimeSeries.php on line 671`
Feed 174 uses MYSQL Memory as Engine.
The Size was 16MB, a reboot did not help, nor did a Clear or Trim. Only a delete has helped here.
Since I have other feeds that use MYSQL Memory as Engine, I have noticed that they do not get reduced after a reboot.
I would be grateful for a Solution.
Server Information
Server Information
Services
  • emonhub :- Active Running
  • emoncms_mqtt :- Active Running
  • feedwriter :- Active Running - sleep 300s 196 feed points pending write
  • service-runner :- Active Running
  • redis-server :- Active Running
  • mosquitto :- Active Running
  • emonPiLCD :- Inactive loaded inactive dead
  • emoncms_sync :- Inactive loaded inactive dead
  • demandshaper :- Not found or not installed
Emoncms
Server
  • CPU :- Cortex-A76 | 1 Threads(s) | - Sockets(s) | 108,00MIPS |
  • OS :- Linux 6.6.31+rpt-rpi-v8
  • Host :- emonpi5 | emonpi5 | (10.255.255.27)
  • Date :- 2024-12-15 17:46:12 CET
  • Uptime :- 17:46:12 up 1:00, 0 user, load average: 0,16, 0,15, 0,17
Memory
  • RAM :- Used: 13,30%
    • Total :- 3.9 GB
    • Used :- 531.03 MB
    • Free :- 3.38 GB
  • Swap :- Used: 0,00%
    • Total :- 200 MB
    • Used :- 0 B
    • Free :- 200 MB
Disk
  • **** :- - / :- Used: 29,94%
    • Total :- 14.69 GB
    • Used :- 4.4 GB
    • Free :- 9.62 GB
    • Read Load :- 21.53 B/s
    • Write Load :- 1.02 B/s
    • Load Time :- 113 days 1 hours 43 mins
  • /boot/firmware :- Used: 18,64%
    • Total :- 509.99 MB
    • Used :- 95.05 MB
    • Free :- 414.94 MB
    • Read Load :- n/a
    • Write Load :- n/a
    • Load Time :- n/a
  • /var/opt/emoncms :- Used: 0,39%
    • Total :- 43.32 GB
    • Used :- 172.5 MB
    • Free :- 40.95 GB
    • Read Load :- 0.7 B/s
    • Write Load :- 0.58 B/s
  • /var/log :- Used: 11,41%
    • Total :- 50 MB
    • Used :- 5.7 MB
    • Free :- 44.3 MB
    • Read Load :- n/a
    • Write Load :- n/a
    • Load Time :- n/a
HTTP
  • Server :- Apache/2.4.61 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
  • Version :- 10.11.3-MariaDB-1+rpi1
  • Host :- 127.0.0.1 (127.0.0.1)
  • Date :- 2024-12-15 17:46:11 (UTC 01:00‌​)
  • Stats :- Uptime: 3639 Threads: 29 Questions: 70485 Slow queries: 0 Opens: 359 Open tables: 349 Queries per second avg: 19.369
Redis
  • Version :-
    • Redis Server :- 7.0.15
    • PHP Redis :- 6.0.3-dev
  • Host :- localhost:6379
  • Size :- 1923 keys (1.78M)
  • Uptime :- 0 days
MQTT Server
  • Version :- Mosquitto 2.0.11
  • Host :- localhost:1883 (127.0.0.1)
PHP
  • Version :- 8.1.29 (Zend Version 4.1.29)
  • Run user :- User: www-data Group: www-data video Script Owner: pi
  • Modules :- apache2handler calendar Core ctype curl date exif FFI fileinfo filter ftp gd gettext hash iconv json libxml mbstring mosquitto v0.4.0mysqli mysqlnd vmysqlnd 8.1.29openssl pcre PDO pdo_mysql Phar posix readline redis v6.0.3-devReflection session shmop sockets sodium SPL standard sysvmsg sysvsem sysvshm tokenizer Zend OPcache zlib
Client Information
Client Information
HTTP
  • Browser :- Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:109.0) Gecko/20100101 Firefox/115.0
  • Language :- de,en-US;q=0.7,en;q=0.3
Window
  • Size :- 1903 x 940
Screen
  • Resolution :- 1920 x 1080
Hello @Luiflm2
It looks like this might be being caused by the size of the in memory feed reaching the maximum in memory table size default in mariadb/mysql.
Checking an emonSD image here I can see the default max size is 16MB which matches the size you are seeing…
Could you try:
sudo nano /etc/mysql/conf.d/mysql.cnf
this should bring up a mostly empty file with just the heading [mysql], add the section titled [mysqld] to the bottom e.g:
[mysql]
[mysqld]
tmp_table_size=128MB
max_heap_table_size=128MB
Restart mariadb:
sudo systemctl restart mariadb.service
That will hopefully sort it…
Thank you for your Feedback, I have implemented the configuration and will continue testing.
I wish you and the Team a Merry Christmas and thank you for being there for us. Of course I also wish everyone else in the forum a Merry Christmas.
