Hi there,
I am running
OpenEnergyMonitor.org | low-write 9.8.31 | 2018.06.21
for a couple of weeks and worked well. During the weeks I added some more input calculations and used the associated feed in graphs. Now after first reboot the new feeds are missing and also the new calculation on input have disappeared. I did a test and made a new calculation/feed. That worked fine but after reboot also vanished. I am puzzeld, looks like the changes only exist in memory and got lost after reboot.
Not clear what happens. Has this do with log files? I noticed size of log has changed.
pi@raspberrypi:~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 59G 5.0G 52G 9% /
devtmpfs 460M 0 460M 0% /dev
tmpfs 464M 0 464M 0% /dev/shm
tmpfs 464M 6.2M 458M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 464M 0 464M 0% /sys/fs/cgroup
tmpfs 30M 7.2M 23M 24% /var/log
tmpfs 30M 16K 30M 1% /tmp
/dev/mmcblk0p1 43M 22M 21M 52% /boot
tmpfs 93M 0 93M 0% /run/user/1000
and after reboot:
tmpfs 30M 380K 30M 2% /var/log
tmpfs 30M 4.0K 30M 1% /tmp
My mount is:
/dev/mmcblk0p2 on / type ext4 (rw,noatime,block_validity,delalloc,barrier,user_xattr,acl)
devtmpfs on /dev type devtmpfs (rw,relatime,size=470116k,nr_inodes=117529,mode=755)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cg roups-agent,name=systemd)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=25,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
mqueue on /dev/mqueue type mqueue (rw,relatime)
sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
tmpfs on /var/log type tmpfs (rw,nosuid,nodev,relatime,size=30720k)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime,size=30720k)
/dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors= remount-ro)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=94944k,mode=700,uid=1000,gid=1000)
tracefs on /sys/kernel/debug/tracing type tracefs (rw,relatime)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
Any help/support is appreciated
Jan
