Pukka
(Paul)
15 November 2018 17:27
1
I have been using the new image, restored a backup and after 5 days the feed writer service has stopped.
Server Information
Emoncms
Version
low-write 9.9.4
Modules
Administration : App v1.2.0 : Backup v1.1.5 : EmonHub Config v1.0.0 : Dashboard v1.3.1 : Device v1.2.0 : EventProcesses : Feed : Graph v1.2.1 : Input : Postprocess v1.0.0 : CoreProcess : Schedule : Network Setup v1.0.0 : sync : Time : User : Visualisation : WiFi v1.3.0
Git URL
GitHub - emoncms/emoncms: Web-app for processing, logging and visualising energy, temperature and other environmental data
Git Branch
* stable
Buffer
loading…
Writer
Daemon is not running, start it at ~/scripts/feedwriter
Server
OS
Linux 4.14.71-v7+
Host
emonpi emonpi (192.168.1.215)
Date
2018-11-15 17:24:48 UTC
Uptime
17:24:48 up 5 days, 2:42, 1 user, load average: 0.22, 0.29, 0.37
HTTP
Server
Apache/2.4.25 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
Version
5.5.5-10.1.23-MariaDB-9+deb9u1
Host
127.0.0.1 (127.0.0.1)
Date
2018-11-15 17:24:48 (UTC 00:00)
Stats
Uptime: 441727 Threads: 2 Questions: 4843849 Slow queries: 0 Opens: 46 Flush tables: 1 Open tables: 40 Queries per second avg: 10.965
Redis
Version
3.2.6
Host
localhost:6379 (127.0.0.1)
Size
507 keys (135.13M)
Uptime
0 days
MQTT Server
Version
Mosquitto 1.4.10
Host
localhost:1883 (127.0.0.1)
Pi
Model
Raspberry Pi 3 Model B Rev 1.2 - 1 GB (Sony UK)
SoC
Broadcom BCM2835
Serial num.
43DDB2EE
Temperature
CPU: 58.00°C - GPU: 58.5’C
Release
emonSD-30Oct18
File-system
Current: read-write - Set root file-system temporarily to read-write, (default read-only)
Memory
RAM
Used: 51.18% Total: 976.74 MB Used: 499.85 MB Free: 476.89 MB
Swap
Used: 99.43% Total: 100 MB Used: 99.43 MB Free: 584 KB
Disk
Mount
Stats
Used: 42.24% Total: 3.81 GB Used: 1.61 GB Free: 2.02 GB
/boot
Used: 51.69% Total: 42.52 MB Used: 21.98 MB Free: 20.54 MB
/home/pi/data
Used: 69.39% Total: 3.21 GB Used: 2.23 GB Free: 838.22 MB
PHP
Version
7.0.30-0+deb9u1 (Zend Version 3.0.0)
Modules
apache2handler : calendar v7.0.30-0+deb9u1 : Core v7.0.30-0+deb9u1 : ctype v7.0.30-0+deb9u1 : curl v7.0.30-0+deb9u1 : date v7.0.30-0+deb9u1 : dom v20031129 : exif v7.0.30-0+deb9u1 : fileinfo v1.0.5 : filter v7.0.30-0+deb9u1 : ftp v7.0.30-0+deb9u1 : gd v7.0.30-0+deb9u1 : gettext v7.0.30-0+deb9u1 : hash v1.0 : iconv v7.0.30-0+deb9u1 : igbinary v2.0.1 : json v1.4.0 : libxml v7.0.30-0+deb9u1 : mbstring v7.0.30-0+deb9u1 : mcrypt v7.0.30-0+deb9u1 : mosquitto v0.4.0 : mysqli v7.0.30-0+deb9u1 : mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $ : openssl v7.0.30-0+deb9u1 : pcre v7.0.30-0+deb9u1 : PDO v7.0.30-0+deb9u1 : pdo_mysql v7.0.30-0+deb9u1 : Phar v2.0.2 : posix v7.0.30-0+deb9u1 : readline v7.0.30-0+deb9u1 : redis v4.1.1 : Reflection v7.0.30-0+deb9u1 : session v7.0.30-0+deb9u1 : shmop v7.0.30-0+deb9u1 : SimpleXML v7.0.30-0+deb9u1 : sockets v7.0.30-0+deb9u1 : SPL v7.0.30-0+deb9u1 : standard v7.0.30-0+deb9u1 : sysvmsg v7.0.30-0+deb9u1 : sysvsem v7.0.30-0+deb9u1 : sysvshm v7.0.30-0+deb9u1 : tokenizer v7.0.30-0+deb9u1 : wddx v7.0.30-0+deb9u1 : xml v7.0.30-0+deb9u1 : xmlreader v7.0.30-0+deb9u1 : xmlwriter v7.0.30-0+deb9u1 : xsl v7.0.30-0+deb9u1 : Zend OPcache v7.0.30-0+deb9u1 : zlib v7.0.30-0+deb9u1
Client Information
HTTP
Browser
Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:60.0) Gecko/20100101 Firefox/60.0
Screen
Resolution
1920 x 1080
Window
Size
1903 x 966
Thanks for letting us know @Pukka . Did you get it back up ok? Did anything appear in the Admin > Logger section (/var/log/emoncms.log) Will keep an eye on this.
Pukka
(Paul)
16 November 2018 11:52
3
Hi @TrystanLea
I manually restarted the feed writer server and the pending log went down. it looks like the data has been lost.
I can post the logs later today
Pukka
(Paul)
17 November 2018 09:50
4
Log files attached
emonpiupdate (2).txt (7.7 KB)
emoncms(4).txt (4 KB)
