Feed view unavailable
Hello,
I updated to 10.9.10 thanks to git pull origin master. But now I don’t have access to the feed view anymore, instead, I have an error message:
EmonCMS Error
Message: SyntaxError: JSON.parse: unexpected non-whitespace character after JSON data at line 1 column 2 of the JSON data
Route: feed/view
Line: 928
Column: 27
In addition, Redis doesn’t seem to work anymore:
While I can confirm that:
  1. In /var/www/html/emoncms/settings.php, I have
"redis"=>array(
    'enabled' => true
redisbuffer'   => array(
        'enabled' => false,
        'sleep' => 60
  1. redis-cli ping returns PONG
  2. sudo ps aux | grep redis returns
redis     3083  0.0  1.0 778396 75224 ?        Sl   00:22   0:00 /var/www/onlyoffice/documentserver/server/DocService/docservice
redis     3094  0.0  0.6 594104 51068 ?        Sl   00:22   0:00 /var/www/onlyoffice/documentserver/server/FileConverter/converter
redis     3100  0.0  0.9 713152 73856 ?        Sl   00:22   0:00 /var/www/onlyoffice/documentserver/server/FileConverter/converter /snapshot/server/build/server/FileConverter/sources/convertermaster.js
redis    20270  0.7  0.2  60900 16052 ?        Ssl  01:42   0:00 /usr/bin/redis-server 127.0.0.1:6379*
  1. sudo systemctl status redis returns:
redis-server.service - Advanced key-value store
   Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
   Active: activating (start) since Mon 2021-11-15 01:44:06 CET; 1min 15s ago
     Docs: http://redis.io/documentation,
           man:redis-server(1)
Cntrl PID: 20440 (redis-server)
    Tasks: 4 (limit: 4915)
   Memory: 15.2M
   CGroup: /system.slice/redis-server.service
           └─20440 /usr/bin/redis-server 127.0.0.1:6379
  1. I don’t know if it’s related, but I see a lot of errors like this in the log:
    |WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/345.meta'
  2. Other parts of emoncms (dashboard, input, graph) work well
Config: Debian Buster, Apache, php8.0-fpm
Redis server v=5.0.14
Would anybody have an idea?
Hello, I’m still blocked with this issue. Would anybody have an idea? Thanks for your support!
The php info I’m getting is:
Hello @sisim sorry I missed your post, do you see data when you look at graphs and dashboards?
What kind of system is this on? is it a raspberrypi based install? I assume self configured not emonSD?
Hi @TrystanLea , please don’t be sorry, you’re so nice to consider my issue :slight_smile:
I do see data on graphs and dashboards, it works. All the IotaWatts which are connected are visible in those data, and data is uptodate.
The system is a Debian server (not raspberry):
Debian GNU/Linux 10 (buster)
Server version: Apache/2.4.38 (Debian)
PHP 8.0.13 (cli) (built: Nov 22 2021 09:48:13) ( NTS )
mariadb Ver 15.1 Distrib 10.3.31-MariaDB, for debian-linux-gnu (x86_64) using readline 5.2
Redis server v=5.0.14 sha=00000000:0 malloc=jemalloc-5.1.0 bits=64 build=ddd3b1f304a7d4d5
CPU: 4.19.0-18-amd64
x86_64
We configured it ourselves, and it worked up to now (even if we had some server load issues in the past that you helped to solve: High server load - #18 by sisim - since then, we upgraded the hardware and everything was working fine).
The current issue might also be related to an update of the system, which went to PHP 8.1. After this update, Emoncms wasn’t working anymore, so I updated emoncms (git pull origin master, currently 10.9.19). It was still not working, so I removed PHP 8.1 and reinstalled PHP 8.0 (currently 8.0.13). Then emoncms is working again, except the feed page.
There was probably something broken in those changes. What I don’t understand, is that all other applications on the server, also using PHP, don’t have any issue (Nextcloud, OnlyOffice, Wallabag, Mattermost, …).
Here is the admin page:
Server Information
Server Information
Services
  • redis-server :- Activating loaded activating start
  • feedwriter :- Inactive loaded inactive dead
  • emonhub :- Not found or not installed
  • emoncms_mqtt :- Not found or not installed
  • service-runner :- Not found or not installed
  • emonPiLCD :- Not found or not installed
  • mosquitto :- Not found or not installed
  • demandshaper :- Not found or not installed
Emoncms
Server
  • Machine :- ASRock/B550M-ITX/ac, BIOS P1.80 08/09/2021
  • CPU :- 2 Threads(s) | 4 Core(s) | 1 Sockets(s) | AMD Ryzen 3 4300GE with Radeon Graphics | 2182.349MHz | 6987.38MIPS |
  • OS :- Linux 4.19.0-18-amd64
  • Host :- ServerA1 | ServerA1.cyclo | (192.168.1.31)
  • Date :- 2021-12-08 13:34:00 CET
  • Uptime :- 13:34:00 up 1:06, 2 users, load average: 0.07, 0.20, 0.21
Memory
  • RAM :- Used: 29.92%
    • Total :- 7.17 GB
    • Used :- 2.15 GB
    • Free :- 5.02 GB
  • Swap :- Used: 0.00%
    • Total :- 3.73 GB
    • Used :- 0 B
    • Free :- 3.73 GB
Disk
  • **** :- - / :- Used: 36.25%
    • Total :- 105.86 GB
    • Used :- 38.37 GB
    • Free :- 62.07 GB
    • Read Load :- 479 B/s
    • Write Load :- 1.37 KB/s
    • Load Time :- 23 days 14 hours 11 mins
  • /media/raid :- Used: 91.56%
    • Total :- 915.77 GB
    • Used :- 838.52 GB
    • Free :- 30.67 GB
    • Read Load :- 18.33 B/s
    • Write Load :- 54.12 B/s
HTTP
  • Server :- Apache/2.4.38 (Debian) HTTP/2.0 CGI/1.1 443
MySQL
  • Version :- 5.5.5-10.3.31-MariaDB-0+deb10u1
  • Host :- localhost (127.0.0.1)
  • Date :- 2021-12-08 13:34:00 (UTC 01:00‌​)
  • Stats :- Uptime: 3983 Threads: 36 Questions: 493390 Slow queries: 0 Opens: 334 Flush tables: 1 Open tables: 327 Queries per second avg: 123.873
Redis
  • Version :-
    • Redis Server :- 5.0.14
    • PHP Redis :- 5.3.4
  • Host :- localhost:6379
  • Size :- 1550 keys (7.36M)
  • Uptime :- 0 days
PHP
  • Version :- 8.0.13 (Zend Version 4.0.13)
  • Run user :- User: www-data Group: www-data redis Script Owner: bob
  • Modules :- apcu v5.1.21bcmath bz2 calendar cgi-fcgi Core ctype curl date dom v20031129exif FFI fileinfo filter ftp gd gettext gmp hash iconv igbinary v3.2.6imagick v3.5.1intl json ldap libxml mbstring mysqli mysqlnd vmysqlnd 8.0.13openssl pcre PDO pdo_mysql Phar posix readline redis v5.3.4Reflection session shmop SimpleXML sockets sodium SPL standard sysvmsg sysvsem sysvshm tidy tokenizer xml xmlreader xmlwriter xsl Zend OPcache zip v1.19.5zlib
Client Information
Client Information
HTTP
  • Browser :- Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0
  • Language :- en,q=0.5
In the log, I just see this:
`/var/log/emoncms/emoncms.log` 2021-12-08 12:34:49.312|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/350.meta' 2021-12-08 12:34:49.312|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/350.meta' 2021-12-08 12:34:49.312|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/351.meta' 2021-12-08 12:34:49.312|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/351.meta' 2021-12-08 12:34:49.313|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/356.meta' 2021-12-08 12:34:49.313|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/356.meta' 2021-12-08 12:34:49.321|WARN|feed_model.php|Feed model: Requested feed does not exist feedid=71 2021-12-08 12:34:54.179|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/330.meta' 2021-12-08 12:34:54.179|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/330.meta' 2021-12-08 12:34:54.180|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/337.meta' 2021-12-08 12:34:54.181|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/337.meta' 2021-12-08 12:34:54.181|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/341.meta' 2021-12-08 12:34:54.181|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/341.meta' 2021-12-08 12:34:54.181|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/344.meta' 2021-12-08 12:34:54.181|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/344.meta' 2021-12-08 12:34:54.181|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/345.meta' 2021-12-08 12:34:54.181|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/345.meta' 2021-12-08 12:34:54.182|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/349.meta' 2021-12-08 12:34:54.182|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/349.meta' 2021-12-08 12:34:54.182|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/350.meta' 2021-12-08 12:34:54.182|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/350.meta' 2021-12-08 12:34:54.182|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/351.meta' 2021-12-08 12:34:54.182|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/351.meta' 2021-12-08 12:34:54.183|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/356.meta' 2021-12-08 12:34:54.184|WARN|PHPFina.php|get_meta() meta file does not exist '/var/opt/emoncms/phpfina/356.meta'
Going through the full log, here are potentially interesting lines 2021-12-08 06:16:22.654|ERROR|index.php|Not Authenticated|dashboard/edit 2021-12-08 06:16:23.497|ERROR|index.php|Not Authenticated|dashboard/edit 2021-12-08 06:16:23.498|ERROR|index.php|Not Authenticated|input/view 2021-12-08 06:43:36.265|ERROR|input_controller.php|{"success": false, "message": "Error: Reached the maximal allowed number of different NodeIds, limit is 32. Node 'IotaWatt' was ignored."} for User: 1 2021-12-08 06:43:37.748|ERROR|index.php|Not Authenticated|input/list 2021-12-08 06:43:56.117|ERROR|input_controller.php|{"success": false, "message": "Error: Reached the maximal allowed number of different NodeIds, limit is 32. Node 'IotaWatt' was ignored."} for User: 1 2021-12-08 06:44:12.127|ERROR|input_controller.php|{"success": false, "message": "Error: Reached the maximal allowed number of different NodeIds, limit is 32. Node 'IotaWatt' was ignored."} for User: 1 2021-12-08 06:44:30.165|ERROR|input_controller.php|{"success": false, "message": "Error: Reached the maximal allowed number of different NodeIds, limit is 32. Node 'IotaWatt' was ignored."} for User: 1 2021-12-08 06:45:43.759|ERROR|input_controller.php|{"success": false, "message": "Error: Reached the maximal allowed number of different NodeIds, limit is 32. Node 'IotaWatt' was ignored."} for User: 1 2021-12-08 06:46:01.948|ERROR|input_controller.php|{"success": false, "message": "Error: Reached the maximal allowed number of different NodeIds, limit is 32. Node 'IotaWatt' was ignored."} for User: 1 2021-12-08 12:34:49.215|WARN|feed_model.php|Feed model: Requested feed does not exist feedid=70
I think it’s probably related to the errors with the missing meta files:
Could you check the content of /var/opt/emoncms/phpfina:
ls -lh /var/opt/emoncms/phpfina
total 1.3G
-rw-r--r-- 1 www-data www-data 4.6M Dec  8 14:21 100.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 12:28 100.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 101.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 101.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 102.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 102.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 103.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 103.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 104.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 104.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 105.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 105.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 106.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 106.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 107.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 107.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 108.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 108.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 109.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 109.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 111.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 111.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 112.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 112.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 113.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 113.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 114.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 114.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 115.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 115.meta
-rw-r--r-- 1 www-data www-data 8.0M Nov 30 15:14 116.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 14:47 116.meta
-rw-r--r-- 1 www-data www-data  14M Dec  8 14:21 117.dat
-rw-r--r-- 1 www-data www-data   16 Jul 22 16:01 117.meta
-rw-r--r-- 1 www-data www-data 9.7M Dec  8 14:21 118.dat
-rw-r--r-- 1 www-data www-data   16 Jul 23 09:12 118.meta
-rw-r--r-- 1 www-data www-data 9.7M Dec  8 14:21 119.dat
-rw-r--r-- 1 www-data www-data   16 Jul 23 09:12 119.meta
-rw-r--r-- 1 www-data www-data 9.7M Dec  8 14:21 120.dat
-rw-r--r-- 1 www-data www-data   16 Jul 23 09:12 120.meta
-rw-r--r-- 1 www-data www-data 9.7M Dec  8 14:21 121.dat
-rw-r--r-- 1 www-data www-data   16 Jul 23 09:12 121.meta
-rw-r--r-- 1 www-data www-data 9.7M Dec  8 14:21 122.dat
-rw-r--r-- 1 www-data www-data   16 Jul 23 09:12 122.meta
-rw-r--r-- 1 www-data www-data 9.7M Dec  8 14:21 123.dat
-rw-r--r-- 1 www-data www-data   16 Jul 23 09:12 123.meta
-rw-r--r-- 1 www-data www-data 9.7M Dec  8 14:21 124.dat
-rw-r--r-- 1 www-data www-data   16 Jul 23 09:12 124.meta
-rw-r--r-- 1 www-data www-data 9.7M Dec  8 14:21 125.dat
-rw-r--r-- 1 www-data www-data   16 Jul 23 09:12 125.meta
-rw-r--r-- 1 www-data www-data 9.7M Dec  8 14:21 126.dat
-rw-r--r-- 1 www-data www-data   16 Jul 23 09:12 126.meta
-rw-r--r-- 1 www-data www-data 9.7M Dec  8 14:21 127.dat
-rw-r--r-- 1 www-data www-data   16 Jul 23 09:12 127.meta
-rw-r--r-- 1 www-data www-data 9.7M Dec  8 14:21 128.dat
-rw-r--r-- 1 www-data www-data   16 Jul 23 09:12 128.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 130.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 14:54 130.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 131.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:04 131.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 146.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:14 146.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 151.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:17 151.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 152.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:17 152.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 153.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:17 153.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 154.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:17 154.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 155.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:17 155.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 156.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:17 156.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 157.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:29 157.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 158.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:31 158.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 159.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:31 159.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 160.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:31 160.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 161.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:31 161.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 162.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:32 162.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 163.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:32 163.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 164.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:32 164.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 165.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:32 165.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 166.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:32 166.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 167.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:34 167.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 168.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:34 168.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 169.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:34 169.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 170.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:34 170.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 171.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:36 171.meta
-rw-r--r-- 1 www-data www-data 4.5M Dec  8 14:21 172.dat
-rw-r--r-- 1 www-data www-data   16 Jul 27 15:36 172.meta
-rw-r--r-- 1 www-data www-data  22M Nov 30 15:14 173.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 08:49 173.meta
-rw-r--r-- 1 www-data www-data  11M Dec  8 14:21 174.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 09:48 174.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 14:21 175.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 08:51 175.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 14:21 176.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 11:00 176.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 14:21 177.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 08:54 177.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 178.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:02 178.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 180.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:02 180.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 181.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:03 181.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 182.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:03 182.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 183.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:03 183.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 184.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:03 184.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 185.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:03 185.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 186.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:05 186.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 187.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:05 187.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 188.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:05 188.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 189.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:05 189.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 190.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:05 190.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 191.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:05 191.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 192.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:05 192.meta
-rw-r--r-- 1 www-data www-data 4.4M Dec  8 11:28 194.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:08 194.meta
-rw-r--r-- 1 www-data www-data 2.9M Oct 30 14:10 195.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:09 195.meta
-rw-r--r-- 1 www-data www-data 2.9M Oct 30 14:10 196.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:52 196.meta
-rw-r--r-- 1 www-data www-data 2.9M Oct 30 14:10 197.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:52 197.meta
-rw-r--r-- 1 www-data www-data 2.9M Oct 30 14:10 198.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:52 198.meta
-rw-r--r-- 1 www-data www-data 2.9M Oct 30 14:10 199.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:54 199.meta
-rw-r--r-- 1 www-data www-data 2.9M Oct 30 15:51 200.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:54 200.meta
-rw-r--r-- 1 www-data www-data 2.9M Oct 30 15:51 201.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:54 201.meta
-rw-r--r-- 1 www-data www-data 2.9M Oct 30 15:51 202.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:54 202.meta
-rw-r--r-- 1 www-data www-data 2.9M Oct 30 15:51 203.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:54 203.meta
-rw-r--r-- 1 www-data www-data 2.9M Oct 30 15:51 204.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:56 204.meta
-rw-r--r-- 1 www-data www-data 2.9M Oct 30 15:51 205.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:56 205.meta
-rw-r--r-- 1 www-data www-data 2.9M Oct 30 15:51 206.dat
-rw-r--r-- 1 www-data www-data   16 Jul 28 13:56 206.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 12:24 209.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:07 209.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 12:24 210.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:10 210.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 12:24 211.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:11 211.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 12:24 212.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:11 212.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 12:24 213.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:11 213.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 12:24 214.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:11 214.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 12:24 215.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:11 215.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 12:24 216.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:12 216.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 12:24 217.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:12 217.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 12:24 218.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:12 218.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 12:24 219.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:14 219.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 12:24 220.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:14 220.meta
-rw-r--r-- 1 www-data www-data 7.0M Dec  8 13:12 221.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:51 221.meta
-rw-r--r-- 1 www-data www-data 7.0M Dec  8 13:12 222.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:52 222.meta
-rw-r--r-- 1 www-data www-data 7.0M Dec  8 13:12 223.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:52 223.meta
-rw-r--r-- 1 www-data www-data 7.0M Dec  8 13:12 225.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:52 225.meta
-rw-r--r-- 1 www-data www-data 7.0M Dec  8 13:12 226.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:53 226.meta
-rw-r--r-- 1 www-data www-data 7.0M Dec  8 13:12 227.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:53 227.meta
-rw-r--r-- 1 www-data www-data 7.0M Dec  8 13:12 228.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:55 228.meta
-rw-r--r-- 1 www-data www-data 7.0M Dec  8 13:12 229.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:55 229.meta
-rw-r--r-- 1 www-data www-data 7.0M Dec  8 13:12 230.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:55 230.meta
-rw-r--r-- 1 www-data www-data 7.0M Dec  8 13:12 231.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:56 231.meta
-rw-r--r-- 1 www-data www-data 7.0M Dec  8 13:12 232.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:56 232.meta
-rw-r--r-- 1 www-data www-data 7.0M Dec  8 13:12 233.dat
-rw-r--r-- 1 www-data www-data   16 Aug  5 14:56 233.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 14:21 234.dat
-rw-r--r-- 1 www-data www-data   16 Aug 11 09:31 234.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 14:21 235.dat
-rw-r--r-- 1 www-data www-data   16 Aug 11 09:31 235.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 14:21 236.dat
-rw-r--r-- 1 www-data www-data   16 Aug 11 09:31 236.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 14:21 237.dat
-rw-r--r-- 1 www-data www-data   16 Aug 11 09:31 237.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 14:21 238.dat
-rw-r--r-- 1 www-data www-data   16 Aug 11 09:31 238.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 14:21 240.dat
-rw-r--r-- 1 www-data www-data   16 Aug 11 09:31 240.meta
-rw-r--r-- 1 www-data www-data 4.2M Dec  8 14:21 241.dat
-rw-r--r-- 1 www-data www-data   16 Aug 11 09:31 241.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 242.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 09:53 242.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 243.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 10:02 243.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 244.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 10:02 244.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 245.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 10:02 245.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 246.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 10:04 246.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 247.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 10:04 247.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 248.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 10:04 248.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 249.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 10:05 249.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 250.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 10:05 250.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 251.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 10:05 251.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 252.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 10:05 252.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 253.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 10:05 253.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 254.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 15:25 254.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 255.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 15:25 255.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 256.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 15:25 256.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 257.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 15:26 257.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 258.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 15:26 258.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 259.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 15:27 259.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 260.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 15:27 260.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 261.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 15:27 261.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 262.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 15:27 262.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 263.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 15:27 263.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 264.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 15:28 264.meta
-rw-r--r-- 1 www-data www-data 3.8M Dec  8 14:21 265.dat
-rw-r--r-- 1 www-data www-data   16 Aug 17 15:28 265.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 13:14 266.dat
-rw-r--r-- 1 www-data www-data   16 Aug 19 12:47 266.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 13:14 267.dat
-rw-r--r-- 1 www-data www-data   16 Aug 19 12:48 267.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 13:14 268.dat
-rw-r--r-- 1 www-data www-data   16 Aug 19 12:48 268.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 13:14 269.dat
-rw-r--r-- 1 www-data www-data   16 Aug 19 12:48 269.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 13:14 270.dat
-rw-r--r-- 1 www-data www-data   16 Aug 19 12:49 270.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 13:14 271.dat
-rw-r--r-- 1 www-data www-data   16 Aug 19 12:49 271.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 13:14 272.dat
-rw-r--r-- 1 www-data www-data   16 Aug 19 12:49 272.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 13:14 273.dat
-rw-r--r-- 1 www-data www-data   16 Aug 19 12:49 273.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 13:14 274.dat
-rw-r--r-- 1 www-data www-data   16 Aug 19 12:50 274.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 13:14 275.dat
-rw-r--r-- 1 www-data www-data   16 Aug 19 12:50 275.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 13:14 276.dat
-rw-r--r-- 1 www-data www-data   16 Aug 19 12:50 276.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 13:14 277.dat
-rw-r--r-- 1 www-data www-data   16 Aug 19 12:50 277.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 278.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 278.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 279.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 279.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 280.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 280.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 281.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 281.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 282.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 282.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 283.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 283.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 284.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 284.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 285.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 285.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 286.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 286.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 287.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 287.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 288.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 288.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 289.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 289.meta
-rw-r--r-- 1 www-data www-data 3.7M Dec  8 14:21 290.dat
-rw-r--r-- 1 www-data www-data   16 Aug 20 11:24 290.meta
-rw-r--r-- 1 www-data www-data 3.1M Nov 24 15:16 291.dat
-rw-r--r-- 1 www-data www-data   16 Aug 23 12:58 291.meta
-rw-r--r-- 1 www-data www-data 3.1M Nov 24 15:16 292.dat
-rw-r--r-- 1 www-data www-data   16 Aug 23 12:58 292.meta
-rw-r--r-- 1 www-data www-data 3.1M Nov 24 15:16 293.dat
-rw-r--r-- 1 www-data www-data   16 Aug 23 12:59 293.meta
-rw-r--r-- 1 www-data www-data 3.1M Nov 24 15:16 294.dat
-rw-r--r-- 1 www-data www-data   16 Aug 23 12:59 294.meta
-rw-r--r-- 1 www-data www-data 3.1M Nov 24 15:16 295.dat
-rw-r--r-- 1 www-data www-data   16 Aug 23 12:59 295.meta
-rw-r--r-- 1 www-data www-data 3.1M Nov 24 15:16 296.dat
-rw-r--r-- 1 www-data www-data   16 Aug 23 12:59 296.meta
-rw-r--r-- 1 www-data www-data 3.1M Nov 24 15:16 297.dat
-rw-r--r-- 1 www-data www-data   16 Aug 23 12:59 297.meta
-rw-r--r-- 1 www-data www-data 2.1M Dec  8 14:20 298.dat
-rw-r--r-- 1 www-data www-data   16 Oct  7 15:32 298.meta
-rw-r--r-- 1 www-data www-data 2.1M Dec  8 14:20 299.dat
-rw-r--r-- 1 www-data www-data   16 Oct  7 15:32 299.meta
-rw-r--r-- 1 www-data www-data  18M Nov 30 14:09 29.dat
-rw-r--r-- 1 www-data www-data   16 Jul  8 09:41 29.meta
-rw-r--r-- 1 www-data www-data 2.1M Dec  8 14:20 300.dat
-rw-r--r-- 1 www-data www-data   16 Oct  7 15:32 300.meta
-rw-r--r-- 1 www-data www-data 2.1M Dec  8 14:20 301.dat
-rw-r--r-- 1 www-data www-data   16 Oct  7 15:32 301.meta
-rw-r--r-- 1 www-data www-data 2.1M Dec  8 14:20 302.dat
-rw-r--r-- 1 www-data www-data   16 Oct  7 15:32 302.meta
-rw-r--r-- 1 www-data www-data 2.1M Dec  8 14:20 303.dat
-rw-r--r-- 1 www-data www-data   16 Oct  7 15:32 303.meta
-rw-r--r-- 1 www-data www-data 2.1M Dec  8 14:20 304.dat
-rw-r--r-- 1 www-data www-data   16 Oct  7 15:32 304.meta
-rw-r--r-- 1 www-data www-data 3.1M Dec  8 09:17 305.dat
-rw-r--r-- 1 www-data www-data   16 Sep  9 10:59 305.meta
-rw-r--r-- 1 www-data www-data 3.1M Dec  8 09:17 306.dat
-rw-r--r-- 1 www-data www-data   16 Sep  9 10:59 306.meta
-rw-r--r-- 1 www-data www-data 3.1M Dec  8 09:17 307.dat
-rw-r--r-- 1 www-data www-data   16 Sep  9 10:59 307.meta
-rw-r--r-- 1 www-data www-data 3.1M Dec  8 09:17 308.dat
-rw-r--r-- 1 www-data www-data   16 Sep  9 10:59 308.meta
-rw-r--r-- 1 www-data www-data 3.1M Dec  8 09:17 309.dat
-rw-r--r-- 1 www-data www-data   16 Sep  9 10:59 309.meta
-rw-r--r-- 1 www-data www-data  18M Nov 30 14:09 30.dat
-rw-r--r-- 1 www-data www-data   16 Jul  8 09:42 30.meta
-rw-r--r-- 1 www-data www-data 3.1M Dec  8 09:17 310.dat
-rw-r--r-- 1 www-data www-data   16 Sep  9 10:59 310.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 312.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:02 312.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 313.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:03 313.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 314.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:03 314.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 315.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:03 315.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 316.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:04 316.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 317.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:04 317.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 318.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:04 318.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 319.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:04 319.meta
-rw-r--r-- 1 www-data www-data  18M Nov 30 14:09 31.dat
-rw-r--r-- 1 www-data www-data   16 Jul  8 09:43 31.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 320.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:04 320.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 321.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:04 321.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 322.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:05 322.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 323.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:05 323.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 324.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:05 324.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 325.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:05 325.meta
-rw-r--r-- 1 www-data www-data 2.9M Dec  8 14:00 326.dat
-rw-r--r-- 1 www-data www-data   16 Sep 14 13:06 326.meta
-rw-r--r-- 1 www-data www-data 798K Dec  8 14:21 328.dat
-rw-r--r-- 1 www-data www-data   16 Nov 14 23:18 328.meta
-rw-r--r-- 1 www-data www-data 798K Dec  8 14:21 329.dat
-rw-r--r-- 1 www-data www-data   16 Nov 14 23:18 329.meta
-rw-r--r-- 1 www-data www-data  18M Nov 30 14:09 32.dat
-rw-r--r-- 1 www-data www-data   16 Jul  8 09:58 32.meta
-rw-r--r-- 1 www-data www-data 798K Dec  8 14:21 331.dat
-rw-r--r-- 1 www-data www-data   16 Nov 14 23:18 331.meta
-rw-r--r-- 1 www-data www-data 798K Dec  8 14:21 332.dat
-rw-r--r-- 1 www-data www-data   16 Nov 14 23:18 332.meta
-rw-r--r-- 1 www-data www-data 798K Dec  8 14:21 333.dat
-rw-r--r-- 1 www-data www-data   16 Nov 14 23:18 333.meta
-rw-r--r-- 1 www-data www-data 798K Dec  8 14:21 334.dat
-rw-r--r-- 1 www-data www-data   16 Nov 14 23:18 334.meta
-rw-r--r-- 1 www-data www-data 798K Dec  8 14:21 335.dat
-rw-r--r-- 1 www-data www-data   16 Nov 14 23:18 335.meta
-rw-r--r-- 1 www-data www-data 679K Dec  8 09:17 336.dat
-rw-r--r-- 1 www-data www-data   16 Nov 18 07:19 336.meta
-rw-r--r-- 1 www-data www-data  18M Nov 30 14:09 33.dat
-rw-r--r-- 1 www-data www-data   16 Jul  8 09:58 33.meta
-rw-r--r-- 1 www-data www-data 979K Dec  8 14:21 342.dat
-rw-r--r-- 1 www-data www-data   16 Nov 17 12:33 342.meta
-rw-r--r-- 1 www-data www-data 979K Dec  8 14:21 343.dat
-rw-r--r-- 1 www-data www-data   16 Nov 17 12:33 343.meta
-rw-r--r-- 1 www-data www-data    0 Nov  9 19:12 346.dat
-rw-r--r-- 1 www-data www-data   16 Nov  9 19:12 346.meta
-rw-r--r-- 1 www-data www-data 979K Dec  8 14:21 347.dat
-rw-r--r-- 1 www-data www-data   16 Nov 17 12:33 347.meta
-rw-r--r-- 1 www-data www-data 979K Dec  8 14:21 348.dat
-rw-r--r-- 1 www-data www-data   16 Nov 17 12:33 348.meta
-rw-r--r-- 1 www-data www-data  18M Nov 30 14:09 34.dat
-rw-r--r-- 1 www-data www-data   16 Jul  8 10:00 34.meta
-rw-r--r-- 1 www-data www-data 800K Dec  8 13:44 352.dat
-rw-r--r-- 1 www-data www-data   16 Nov 15 06:00 352.meta
-rw-r--r-- 1 www-data www-data 800K Dec  8 13:44 353.dat
-rw-r--r-- 1 www-data www-data   16 Nov 15 06:00 353.meta
-rw-r--r-- 1 www-data www-data 800K Dec  8 13:44 354.dat
-rw-r--r-- 1 www-data www-data   16 Nov 15 06:00 354.meta
-rw-r--r-- 1 www-data www-data 800K Dec  8 13:44 355.dat
-rw-r--r-- 1 www-data www-data   16 Nov 15 06:00 355.meta
-rw-r--r-- 1 www-data www-data 800K Dec  8 13:44 357.dat
-rw-r--r-- 1 www-data www-data   16 Nov 15 06:00 357.meta
-rw-r--r-- 1 www-data www-data 1.9M Dec  8 14:21 358.dat
-rw-r--r-- 1 www-data www-data   16 Nov 17 12:51 358.meta
-rw-r--r-- 1 www-data www-data 1.4M Dec  8 14:00 359.dat
-rw-r--r-- 1 www-data www-data   16 Nov 17 15:57 359.meta
-rw-r--r-- 1 www-data www-data  18M Nov 30 14:09 35.dat
-rw-r--r-- 1 www-data www-data   16 Jul  8 10:01 35.meta
-rw-r--r-- 1 www-data www-data    0 Nov 18 15:13 360.dat
-rw-r--r-- 1 www-data www-data   16 Nov 18 15:13 360.meta
-rw-r--r-- 1 www-data www-data 1.4M Dec  8 14:21 361.dat
-rw-r--r-- 1 www-data www-data   16 Nov 18 15:14 361.meta
-rw-r--r-- 1 www-data www-data 1.4M Dec  8 14:21 362.dat
-rw-r--r-- 1 www-data www-data   16 Nov 18 15:14 362.meta
-rw-r--r-- 1 www-data www-data 1.4M Dec  8 14:21 363.dat
-rw-r--r-- 1 www-data www-data   16 Nov 18 15:14 363.meta
-rw-r--r-- 1 www-data www-data 1.4M Dec  8 14:21 364.dat
-rw-r--r-- 1 www-data www-data   16 Nov 18 15:14 364.meta
-rw-r--r-- 1 www-data www-data 1.4M Dec  8 14:21 365.dat
-rw-r--r-- 1 www-data www-data   16 Nov 18 15:15 365.meta
-rw-r--r-- 1 www-data www-data 1.4M Dec  8 14:21 366.dat
-rw-r--r-- 1 www-data www-data   16 Nov 18 15:15 366.meta
-rw-r--r-- 1 www-data www-data 1.4M Dec  8 14:21 367.dat
-rw-r--r-- 1 www-data www-data   16 Nov 18 15:15 367.meta
-rw-r--r-- 1 www-data www-data 1.4M Dec  8 14:21 368.dat
-rw-r--r-- 1 www-data www-data   16 Nov 18 15:15 368.meta
-rw-r--r-- 1 www-data www-data 1.4M Dec  8 14:21 369.dat
-rw-r--r-- 1 www-data www-data   16 Nov 18 15:15 369.meta
-rw-r--r-- 1 www-data www-data  51K Nov 19 09:04 370.dat
-rw-r--r-- 1 www-data www-data   16 Nov 18 15:16 370.meta
-rw-r--r-- 1 www-data www-data 1.3M Dec  8 14:21 371.dat
-rw-r--r-- 1 www-data www-data   16 Nov 19 09:04 371.meta
-rw-r--r-- 1 www-data www-data 1.3M Dec  8 14:21 372.dat
-rw-r--r-- 1 www-data www-data   16 Nov 19 09:05 372.meta
-rw-r--r-- 1 www-data www-data 954K Dec  3 13:00 373.dat
-rw-r--r-- 1 www-data www-data   16 Nov 19 10:50 373.meta
-rw-r--r-- 1 www-data www-data 954K Dec  3 13:00 374.dat
-rw-r--r-- 1 www-data www-data   16 Nov 19 10:50 374.meta
-rw-r--r-- 1 www-data www-data 952K Dec  3 13:00 375.dat
-rw-r--r-- 1 www-data www-data   16 Nov 19 10:52 375.meta
-rw-r--r-- 1 www-data www-data 1.1M Dec  8 13:39 376.dat
-rw-r--r-- 1 www-data www-data   16 Nov 22 12:15 376.meta
-rw-r--r-- 1 www-data www-data 1.1M Dec  8 13:39 377.dat
-rw-r--r-- 1 www-data www-data   16 Nov 22 12:15 377.meta
-rw-r--r-- 1 www-data www-data 1.1K Nov 22 12:37 378.dat
-rw-r--r-- 1 www-data www-data   16 Nov 22 12:15 378.meta
-rw-r--r-- 1 www-data www-data 1.1M Dec  8 13:39 379.dat
-rw-r--r-- 1 www-data www-data   16 Nov 22 12:37 379.meta
drwxr-xr-x 2 www-data root     4.0K Jun 18 07:26 sudo
The files are indeed missing: why would it prevent me to access the feed page? Would you know how to solve that?
The error message also slightly changed on https://emoncms.mywebsite.com/feed/list
EmonCMS Error
Route: feed/list
Line: 940
Column: 27
(it was line 928 before, Column 27, see my first post)
Hello @sisim, are you definitely using settings.php and not settings.ini? Could you check this setting? I think your last error might be related to this setting being incorrect…
"feed"=>array(
    // Supported engines. List engines by id to disable feed creation.
    // Existing feeds with a hidden engine still work
    // MYSQL:0, MYSQLMEMORY:8, PHPTIMESERIES:2, PHPFINA:5, CASSANDRA:10
    // 5:phpfina and 2:phptimeseries are the recommended emoncms feed engines
    'engines_hidden'=>array(0,8,10),
Hello @TrystanLea , thanks!
Yes, I use settings.php, and I had 'engines_hidden'=>array(0,6,8,10),
I have changed it to array(0,8,10)
I still have the issue on the feed page. Could you please share which error it should solve?
Yes, the error
Looks like it could be related to that setting…
Feel free to PM me your website address and I can try to follow the line numbers a bit better… and see if I can spot anything else…
I just shared a PM with you, with more info :slight_smile:
Hello @sisim think I’ve got it, could you pull in the latest emoncms core master branch?
Yeah!! It works :slight_smile: Thank you so much for your support @TrystanLea !
(v 10.9.20 now)
