Much as the title says. Is the factoryreset script broken on the Oct19 image? Seems it’s trying to access a load of directories that don’t exist.
For example:
- /home/pi/emonpi
- /home/pi/data
/home/pi is empty.
For example:
/home/pi is empty.
Yes, I don’t think it was updated when the last lot of changes for EmonScript were done.
TBH, unless you have other things on the card you’d probably be better off just re-flashing the image.
It’s more a case of accessibility. Far easier to reset it remotely than dig it out, and dismantle it. I’m being lazy.
I made links to /opt/openenergymonitor/emonpi and data. The script seems to have run. Will see if it’s done the trick.
Edit: I think it’s left the system in a funny state. Looks like I’m going digging.
