Hi all,
I have read some post about expanding SD card, but I’m not sure it will work in my case. I want to be sure that I won’t lose the collected data.
I’m working with 17 june 2015 image, that is mounted on a 8 gb SD card. I didn’t expand, but now the following error occured:
Can't connect to database, please verify credentials/configuration in settings.php
Error message: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
This due to 100% used space:
pi@emonpi ~ $ df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 2.7G 2.2G 309M 88% /
/dev/root 2.7G 2.2G 309M 88% /
devtmpfs 460M 0 460M 0% /dev
tmpfs 93M 284K 93M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 186M 0 186M 0% /run/shm
tmpfs 30M 4.0K 30M 1% /tmp
tmpfs 30M 208K 30M 1% /var/log
/dev/mmcblk0p1 56M 19M 37M 34% /boot
/dev/mmcblk0p3 788M 763M 0 100% /home/pi/data
How can I get access in EmonCMS to my data without losing?
I hope someone can help me out.
