just some basic help please. The information given in the emonhub interfacers section with the above sub-heading provides scripts to assist in getting the Sontex Supercal 5 working.
When going in with ssh, where do I go before entering the scripts?
Other odd thing is whole Emonpi2 inputs now show n/a NULL since attaching Mbus/USB adaptor to the unit.
Hello @Peter_Randall
The emonhub interfacer section that you are refering to is this I assume: https://docs.openenergymonitor.org/emonhub/emonhub-interfacers.html#extra-config-for-sontex-789-supercal5
The commands given there include the full path to the scripts and so you can use those directly from the home folder that you start at after logging in via SSH.
I would check the emonHub log to start with. Is emonHub still running?
