Hi folks… just checked on my evse charge point mounted on wall outside house… and time says 7:45am
Have them come inside house and via web interface taken picture of system time, and that states time as 9:46,… ( ok it took a few seconds to get to pc )
Hi Jeremy,… tx for getting back… as far as I can see using Version: 4.1.7.
TZ as per etc/GMT+1 as we are on BST,… and as far as I can work out there are no auto corrections for BST/GMT…
I assumed the NTP, was a one off press,… as was probably used initially on setup…not sure which NTP server connected to,… but did not want to break things further…
Trust / hope this helps…
Hi Guillaume,… many tx,. have looked at the downloads page and narrowed my options down to the following
But I cannot determine which of the two bin files to download to install,… (as I must be missing the obvious,)… which one do I choose, and where are the docs which explain what each bin file is for,… sorry for being a pain,… as I don’t want bomb my charger, ( yes I can fix it,… its just more ‘pain’ )
Ok,… I’m thinking openevse_wifi_v1_gui-v1.bin ,… as that’s what shows in web UI,… as seems to confirm what I have read in the docs now,…
But it would be nice to know what all the other variants are for to be sure,… is there a table ( what ever ) I am missing,…
Tx guys,… firmware updated… and ‘Time’ looks good,… system time and displayed time now sync’d,… so looking good.
With regards the future I see there will be an upgrade to the actual EVSE firmware to 8.2.3, ( when available ). Has someone created an idiots guide how-to for this upgrade. I have a serial usb programmer ( and have successfully used it to program modules for use with HomeAssisatant ),… so am familiar with re-flashing firmware…
many tx again…
