When the emonPi queris several parameters in sequence, EV charger sometimes will answer out of sequence. Below for example it replies with session watt /total watt data to the time limit request (G3)
{“cmd”:"$G3",“ret”:"$OK 2761672 601624^16"}
This seem to happen more often when the EV is charging. The requests are made using standard node-red http request node. AIs this a known issue ?
