This topic was also brought up on SpeakEV forums. A lot of users took the BBC Click report as “FUD” but IT security issues always need to be addressed for any internet connected device, whether it be EV tech or otherwise.
If we were to look at the EmonEVSE/OpenEVSE products, and break each risk down:
1- Mallicious activity by physical access.
The likelyhood of anyone creeping up onto a driveway to open up a live EVSE box, OpenEVSE based or otherwise is going to be very slim. No bad actor wants to be seen to be sat on your driveway, laptop in tow, trying to do something naughty with an EVSE and risk electrocution in the process! Assuming someone has physically opened up the EVSE. What can they do?
Well, being a modular design, it would be possible to override the contactor to initiate a free charge by applying 230v directly to the coil contactor, working live. You’d be nuts to do that and utterly desperate for a charge. Incredibly unlikely!
Access to home network. If the OpenEVSE/EmonEVSE has an Ethernet connection, you could unplug the onboard Olimex Ethernet board and connect that Ethernet cable to a laptop and, depending on the LAN configuration, access other devices on the network. Again, it would be unlikely to happen as the attacker would easily be spotted doing this. The risk vs reward balance is heavily against the attacker.
If there is an ESP32 WiFi board - I don’t know if the contents of the Flash memory are encrypted or not to gain the WiFi password etc, but in theory it is also possible to Flash new software onto that ESP32 if you are again sat on the driveway, laptop and cable in tow. Very unlikely, as above.
OpenEVSE/EmonEVSEs with a physical button - that button can allow local control to initiate a charge outside the timer schedule for example by someone wanting to “steal electricity” but equally the button can be disabled in software.
2 - Mallicious activity by nearby WiFi access.
If the attacker was nearby and gained access to the WiFi network, then it would be possible to control the EVSE, flash different software to it etc. If an attacker is on your WiFI network, you have bigger problems to worry about than just the EVSE! That’s not the EVSE’s fault.
3 - Remote access from elsewhere on the internet.
The OpenEVSE should only be accessible via the local home network or standing in front of it. I would jolly well hope people are not using port forwarding to access it remotely! Many OpenEVSE users with WiFi or Ethernet access will also have an EmonPi on the network talking to the EVSE, extracting data and maybe using a few HTTP or MQTT commands.
I have no experience using the remote EmonCMS.org server so cannot comment on that. Anyone else care to chip in on any security thoughts of EmonCMS.org?
All in all, I’m not worried about the security of the EmonEVSE, given the location of the physical device makes it unlikely to be attacked and that it remains on the local network for my intended set up.
The one assumption we make here, is that the EmonEVSE is accessible to anyone who already has WiFi or Ethernet access. The device itself has no password protection to the local web page and (from the version I am running, 3.3.2) is not running https. It would be unsuitable to be left on the same network in a corporate setup unless the EVSE was placed on its own restricted network and used for monitoring energy usage etc for a small staff car park charger perhaps?
