Ethernet Gateway + LCD issue
I have just upgraded from WiFi Version 2.x (ESP8266) to an ESP32 based Ethernet Gateway v5.0.2. I am amazed by what a big improvement it is! Really impressive how good the UI looks :slight_smile:
I had a slight problem while installing the board. I used Self Adhesive Velcro to stick it to the top of the enclosure - trying to keep it away from mains voltages:
IMG_9315
However when I put the case back on, I think the LCD terminals were just touching the Ethernet socket and it went a bit crazy:
IMG_9314
Thankfully no permanent damage. I have solved it by putting electrical tape on both the Ethernet socket and the back of the LCD panel.
But it is a bit of a squash getting the Ethernet Gateway board in there. Has anyone else experienced this?
Might be another reason to upgrade the enclosure.
what ESP32 board did you use there?
Thanks,
PNT
It was the ‘official’ one from the OpenEnergyMonitor Shop.
I am fairly sure they were were reselling the Olimex ESP32-GATEWAY, pre-flashed and with a suitable cable.
That’s correct, here’s the documentation for it:
