I’m having so much problems with wifi. My wifi infrastructure is good and I’ve tried anything this past year.
I have this wt32-eth01 board laying around and thought it would be nice if I could make it work with the openevse. I saw a post in github about it, but I can’t make it work.
Does someone had success making this board work as an ethernet controller?
Thanks!
Hello @glyn.hudson ,
I just received the Olimex board rev.G. Could you please point me to the right firmware to burn on it? And a diagram or instructions for the wiring?
Thank you very much!
Thanks for the nice commit
The doubt i had is that the openevse sources doesn’t mention a G revision, only the F. And I didn’t know if I could burn the same firmware. I will try with the development build.
@glyn.hudson Just a small question: The bootloader and partitions binaries that are on the flash command, they slided there or there are supposed to be found somewhere else?
EDIT: Got them from v4.1.4. Not sure if they’re compatible, but it seems to work.
