i have used NodeMCU-PyFlasher-4.0-x64 to program myesp32 controller as described here
with the latest firmware Compiled_Firmware_2021-10-05-10-49
All went fine and the firmware instaled with succes.
but after rebooting the controller this is the output when connecting with putty.
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
ets Jun 8 2016 00:22:57rst:0x10 (RTCWDT_RTC_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8_ __ _| o |_) |\/| (_(| | / |) | | __)
[I][main.cpp:3286] setup(): CONTROLLER - ver:019382f764db386f6cab8d8338ad073d21b7bad0 compiled 2021-10-05T10:47:31.492Z
[I][main.cpp:3291] setup(): ESP32 Chip model = 1, Rev 1, Cores=2, Features=50
[I][HAL_ESP32.cpp:232] ConfigureI2C(): Configure I2C
ESP_ERROR_CHECK_WITHOUT_ABORT failed: esp_err_t 0xffffffff (ESP_FAIL) at 0x40091293
file: “src/HAL_ESP32.cpp” line 60
func: esp_err_t HAL_ESP32::writeByte(i2c_port_t, uint8_t, uint8_t, uint8_t)
expression: i2c_master_cmd_begin(i2c_num, cmd, pdMS_TO_TICKS(100))
[E][HAL_ESP32.cpp:277] ConfigureI2C(): TCA9534APWR Error
[E][HAL_ESP32.h:181] Halt(): SYSTEM HALTED
file: “src/HAL_ESP32.cpp” line 113
func: void HAL_ESP32::Led(uint8_t)
expression: writeByte(I2C_NUM_0, TCA9534APWR_ADDRESS, TCA9534APWR_OUTPUT, TCA9534APWR_Value)
Can anyone help or point me in the right direction to solve this?
Forgot this is the esp32 i bought.
https://www.amazon.de/gp/product/B074RGW2VQ/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
