just to update this thread, I installed a new wifi access point about 2 foot away from the charger. It has not crashed yet. but then again i have not been charging the car via grid or solar. (no sun)
Well since the weekend both of my asp32 have kept working. Early to tell. But what I did was on my DCHP server set it to infinity lease time .
Not sure if this may cause me other issues
But thought I would try it as I am making an assumption that after a certain amount of time the esp 32 would be dropped from my system if lease time expired and it may not be reauthenticating it self . ??? Anyone can give more detail on how this works
Yes, it’s possible to use the ESP32 gateway. I’ve added this as an option in our web store. The board will come pre-configured with the correct hardware connections and firmware It’s a drop in replacement for the WiFi board.
Yes, the esp32-gateway-ethernet FW is now on the releases page. The full docs on how to connect and upload to the esp32-gateway-ethernet boards can be found here:
I’ve created a new thread for wired Ethernet related discussion:
Just to update this, I have had the DHCP lease time set to 10 min and a WIFI access point near the ESP32 and its been 5 days and no loss of network. on friday i will remove the access point and report back.
So today I removed the unifi Access Point and 3 hours later we have lost the web interface. its now broadcasting it own OpenEVSE_7b
WhenI looked about an hour ago the signal was -88 but interestingly our emonESP is showing signal as -91 and its still connected.
hi since i changed the lease time on my dchp server to infinit the esp32 has worked with out interuption for over a week now thet is charging every night …
i think that it is some thing when trying to reconect to the sysem . that is causing issue .
i am using a pi hole dchp server on my system .
