Error when viewing GRAPHS error on line 186
Hi
Al am getting this error when trying to view any graph:
Warning: Unexpected character in input: ’ in /var/www/emoncms/Modules/graph/view.php on line 186
Parse error: syntax error, unexpected ‘<’, expecting end of file in /var/www/emoncms/Modules/graph/view.php on line 186
NOTE: the WARNING line appears many (several hundred?) times… The PARSE ERROR shows only once, at the end
Any pointers?
Thanks in advance
P
Hello @phamiltonsmith This is probably related in some way to your other issue, either an installation issue or perhaps SD card corruption…
Hi Trystan, any way to fix this or would you say its better start from a fresh install?
Much appreciated
P
Did a fresh install and had done with it…!
