borpin
(Brian Orpin)
21
@Geinian_Gomes, have you collected much data? I have just successfully installed emoncms on Ubuntu 18LTS using the scripts GitHub - openenergymonitor/EmonScripts: Emoncms Stack Installation and Update scripts.
The script needs a modified config.ini to work on Ubuntu plus a couple of other minor changes, but it was (almost) painless to install.
When pressing the command presents at the end this error how to solve?
N: Ignoring file ‘mosquitto-jessie.list.1’ in directory ‘/etc/apt/sources.list.d/’ as it has an invalid filename extension
emoncms@emoncms:/usr/bin$
borpin
(Brian Orpin)
23
Can you click here, then paste into a message please?
borpin
(Brian Orpin)
25
You posted an image of your admin page above and in it you can see this button.
If you click the button, it copies the contents of the page. If you then paste (Ctl-V) into a new message it will look like this
Server Information
Server Information
Services
- emonhub :- Active Running
- emoncms_mqtt :- Active Running
- feedwriter :- Active Running - sleep 60s 22 feed points pending write
- service-runner :- Active Running
- emonPiLCD :- Active Running
- redis-server :- Active Running
- mosquitto :- Active Running
Emoncms
- Version :- low-write 10.1.6
- Modules :- Administration | App v2.0.6 | Backup v2.1.2 | EmonHub Config v2.0.4 | Dashboard v2.0.4 | Device v2.0.1 | EventProcesses | Feed | Graph v2.0.4 | Input | Postprocess v2.1.0 | CoreProcess | Schedule | Network Setup v1.0.0 | sync | Time | User | Visualisation | WiFi v2.0.1
- Git :-
Server
- OS :- Linux 4.19.57-v7+
- Host :- emonpi | emonpi | (192.168.7.243)
- Date :- 2019-09-12 12:34:57 UTC
- Uptime :- 12:34:57 up 55 days, 3:27, 1 user, load average: 0.28, 0.11, 0.04
Memory
- RAM :- Used: 20.61%
- Total :- 975.62 MB
- Used :- 201.1 MB
- Free :- 774.52 MB
- Swap :- Used: 0.00%
- Total :- 100 MB
- Used :- 0 B
- Free :- 100 MB
Disk
- / :- Used: 47.04%
- Total :- 3.81 GB
- Used :- 1.79 GB
- Free :- 1.84 GB
- /boot :- Used: 52.42%
- Total :- 42.52 MB
- Used :- 22.29 MB
- Free :- 20.23 MB
- /home/pi/data :- Used: 3.72%
- Total :- 3.21 GB
- Used :- 122.25 MB
- Free :- 2.92 GB
HTTP
- Server :- Apache/2.4.25 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
- Version :- 5.5.5-10.1.23-MariaDB-9+deb9u1
- Host :- localhost:6379 (127.0.0.1)
- Date :- 2019-09-12 12:34:56 (UTC 00:00)
- Stats :- Uptime: 4764441 Threads: 3 Questions: 1121865 Slow queries: 0 Opens: 30 Flush tables: 1 Open tables: 24 Queries per second avg: 0.235
Redis
- Version :- 3.2.6
- Size :- 120 keys (848.92K)
- Uptime :- 55 days
MQTT Server
- Version :- Mosquitto 1.4.10
- Host :- localhost:1883 (127.0.0.1)
PHP
- Version :- 7.0.33-0+deb9u3 (Zend Version 3.0.0)
- Modules :- apache2handler | calendar v7.0.33-0+deb9u3 | Core v7.0.33-0+deb9u3 | ctype v7.0.33-0+deb9u3 | curl v7.0.33-0+deb9u3 | date v7.0.33-0+deb9u3 | dom v20031129 | exif v7.0.33-0+deb9u3 | fileinfo v1.0.5 | filter v7.0.33-0+deb9u3 | ftp v7.0.33-0+deb9u3 | gd v7.0.33-0+deb9u3 | gettext v7.0.33-0+deb9u3 | hash v1.0 | iconv v7.0.33-0+deb9u3 | igbinary v2.0.1 | json v1.4.0 | libxml v7.0.33-0+deb9u3 | mbstring v7.0.33-0+deb9u3 | mcrypt v7.0.33-0+deb9u3 | mosquitto v0.4.0 | mysqli v7.0.33-0+deb9u3 | mysqlnd vmysqlnd 5.0.12-dev - 20150407 - Id: b5c5906d452ec590732a93b051f3827e02749b83 | openssl v7.0.33-0+deb9u3 | pcre v7.0.33-0+deb9u3 | PDO v7.0.33-0+deb9u3 | pdo_mysql v7.0.33-0+deb9u3 | Phar v2.0.2 | posix v7.0.33-0+deb9u3 | readline v7.0.33-0+deb9u3 | redis v4.1.1 | Reflection v7.0.33-0+deb9u3 | session v7.0.33-0+deb9u3 | shmop v7.0.33-0+deb9u3 | SimpleXML v7.0.33-0+deb9u3 | sockets v7.0.33-0+deb9u3 | SPL v7.0.33-0+deb9u3 | standard v7.0.33-0+deb9u3 | sysvmsg v7.0.33-0+deb9u3 | sysvsem v7.0.33-0+deb9u3 | sysvshm v7.0.33-0+deb9u3 | tokenizer v7.0.33-0+deb9u3 | wddx v7.0.33-0+deb9u3 | xml v7.0.33-0+deb9u3 | xmlreader v7.0.33-0+deb9u3 | xmlwriter v7.0.33-0+deb9u3 | xsl v7.0.33-0+deb9u3 | Zend OPcache v7.0.33-0+deb9u3 | zlib v7.0.33-0+deb9u3
Pi
Model :- Raspberry Pi 3 Model B+ Rev 1.3 - 1GB (Sony UK)
Serial num. :- 71604C19
Temperature :- 51.54°C - 50.5°C
emonpiRelease :- emonSD-30Oct18
File-system :- read-write
Client Information
Client Information
HTTP
- Browser :- Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.110 Safari/537.36 Vivaldi/2.7.1628.30
- Language :- en-US,en;q=0.9
Window
Screen
- Resolution :- 1920 x 1080
borpin
(Brian Orpin)
27
So your error now stems from this problem. You must have installed emoncms before the build guide was changed.
@pb66, do you have a solution to remove the old mosquitto install?
can you provide all the git needed to install emoncms on ubuntu?
if possible, it is better to reinstall emoncms again.
following the correct steps.
borpin
(Brian Orpin)
29
Do you want to keep your data and setup? Much easier if you do not.
Are you in a position to start with a fresh Ubuntu install? If not, the problem with mosquitto still needs fixing.
it’s okay to erase the data.
can you redirect to the correct emoncms installation links?
borpin
(Brian Orpin)
32
version of ubuntu I’m using is 16.4, do you have any emoncms compatibility issues?
borpin
(Brian Orpin)
34
That should be fine as it is Stretch based. If you can, move to 18.04 as that is what I have tested this install on.
Okay, I’m updating the ubuntu.
borpin
(Brian Orpin)
36
just to be clear (and I will update the other post, you start the install here for Ubuntu EmonScripts/readme.md at master · openenergymonitor/EmonScripts · GitHub
these emoncms installation steps are for running
in raspberry, it works in local emoncms “ubuntu”?
borpin
(Brian Orpin)
38
You need to start here
wget https://raw.githubusercontent.com/openenergymonitor/EmonScripts/master/install/init.sh
chmod +x init.sh
./init.sh
borpin
(Brian Orpin)
40
I do not understand ‘cargo’ - translation problem I suspect
where the emoncms data will be stored?
has a database ?
