Good night. Has anyone ever seen this error? Could you tell me how to solve it? I am using emoncms as localhost in Windows.
ERROR: Feed could not be created, could not write meta data file fopen (/var/lib/phpfina/20.meta): failed to open stream: No such file or directory.
I’m trying to add a feed.
borpin
(Brian Orpin)
15 February 2019 07:21
2
Hi @Mauricio_Fernando , I do not think you have changed the settings file for paths for your Windows server as those are Unix paths.
## Windows Installation
#### 1) Install WAMP
[http://www.wampserver.com/en/](http://www.wampserver.com/en/)
Download the latest version (PHP4 but will work with PHP3). (~35Mb download). Phpmyadmin is also installed during automatically.
Before downloading the wamp installation file it will likely ask you to install the Microsoft Visual C++ 2010 SPI Redistributable Package (~5Mb download)
<br>
#### 2) Configure your server to accept mod rewrite
Emoncms makes use of htaccess mod_rewrite to create clean URL's while using the front controller and MVC architecture.
On Wampserver, enabling mod-rewrite is simply a case of left-click on your Wamp icon and hover on Apache, then hover over Apache Modules, then click PHP, then click on rewrite-module (you'll need to scroll down the list - it it's ticked, it's enabled). Do a restart all services on Wampserver.
This file has been truncated. show original
Right @borpin . I’m at work now. As soon as I get home I will do as you directed me. I made a code using arduino and current sensor to send localhost and also to the emoncms (I paid the credit to use for a year but still have to associate my account). Thank you as soon as I make the corrections I will let you know. If you want I can make it available too. Sorry for the mistakes in English.
