I raised this as an issue on the emonpi repo on 7 February, but it doesnt seem to have been noticed. When attempting to check for updates, i get this error:
Starting update via service-runner-update.sh (v3.0) >
Filesystem Size Used Avail Use% Mounted on
udev 1.6G 0 1.6G 0% /dev
tmpfs 380M 39M 341M 11% /run
/dev/mmcblk0p2 4.4G 3.4G 856M 80% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 5.0M 16K 5.0M 1% /run/lock
tmpfs 30M 28K 30M 1% /tmp
tmpfs 1.0M 12K 1012K 2% /var/lib/php/sessions
tmpfs 128M 0 128M 0% /var/tmp
/dev/mmcblk0p1 510M 80M 431M 16% /boot/firmware
/dev/mmcblk0p3 9.8G 9.9M 9.3G 1% /var/opt/emoncms
log2ram 50M 3.9M 47M 8% /var/log
- emonSD version: emonSD-06Jan25
- supported images: emonSD-01Feb24 emonSD-20Nov23 emonSD-10Nov22 emonSD-21Jul21 emonSD-08May21 emonSD-24Jul20 emonSD-02Oct19 emonSD-17Oct19
ERROR: emonSD base image old or undefined...update will not continue
See latest verson: https://github.com/openenergymonitor/emonpi/wiki/emonSD-pre-built-SD-card-Download-&-Change-Log
Stopping update
i found one old post from 2018 but nothing newer. Any idea how i can get this updates working? I installed using the instructions here.
