I have installed emoncms as a docker container. I am trying to enable multi user. I understand that I should add enable_multi_user = true
to the [interface]
section of settings.ini, but I am not sure where to find this file when running it as a docker container. Can anyone point me in the right direction?
I found a solution. Not sure if it is the best solution, but it works:
Logged into the container:
docker exec -it emoncms-docker_web_1 /bin/bash
Installed a text editor:
apt update
apt install vim
Edited the settings.ini file:
vi ../emoncms/settings.ini
Added this to the file:
[interface]
After refreshing the login page I was able to add more users
