Hi @CDuffy,
I’ve just tested the new bar graph feature. It seems to work well, one little issue I noticed is the drop down menu selects ‘bar’ as default when the default view is ‘line’. Then means in order to change the display to ‘bar’ the user needs to select line than back to bar to enable the bar view. See screecast illustrating the issue
Would this be possible to fix?
Another idea I had would be to make the multigraph interface cleaner would be to wrap up all the extra functions such as ‘stac’, lock axis, show-tag-name etc in the advanced section.
