We’re working on an install of the emonTX (V4); emonBase; and emonVs (ordered without plug) in Bermuda (single phase).
This will replace an earlier installation of emonPi + emonTX + AC2AC (voltmeter).
The emonVs was ordered without a power plug: it looks like the power for the new installation will need a plug, else extra work to source power to the emonVs, or power for the system comes from where?
Would a emonVs with plug be an easier fix? A US-type plug would be needed for Bermuda: can I simply use a conversion plug from UK or EU to US/Bermuda?
Thank you in advance.
PS We’d like to move to actual encryption with keys - not a fixed key or cryptography XOR fixed key on the device & would gladly offer additional data security to interested folks.
A converter plug will work fine, just ensure you use one that connects the earth wire. Or you order the version without a plug and hard-wire it via a 3A fused spur or 6A MCB.
@TrystanLea can advise on encryption. Currently, I believe encryption is done via a fixed key in the firmware:
