Just bought a emonTxV3 from the store and i set up a pi2 with reciever and emonSD
My house is connected to a IT powersystem (Isolated Terra) and i want to log pulses from my powermeter and use 3 Ct clamps
The ct clamps are not connected yet but i hooked up a pulse counter from the store to the emonTxV3
the pulse counter blinks when the meter blinks and the PI seams to recieve data.
but the counter in my feed in not increasing.
when looking at the emonhub log it seams to recieve the input from the emontx but the pulse counter in not increasing
2017-10-26 07:26:07,037 DEBUG RFM2Pi Discarding RX frame ‘unreliable content’? 7 118 161 132 69 127 33 254 254 178 185 215 69 84 246 7 56 19 219 5 68 (-86)
2017-10-26 07:26:07,366 DEBUG RFM2Pi Discarding RX frame ‘unreliable content’? 0 229 69 187 83 31 134 43 225 214 66 254 255 224 43 46 107 214 133 143 1 (-86)
2017-10-26 07:26:13,297 DEBUG RFM2Pi 53 NEW FRAME : OK 8 0 0 0 0 0 0 0 0 63 100 184 11 184 11 184 11 184 11 184 11 184 11 2 0 0 0 (-28)
2017-10-26 07:26:13,302 DEBUG RFM2Pi 53 Timestamp : 1509002773.3
2017-10-26 07:26:13,303 DEBUG RFM2Pi 53 From Node : 8
2017-10-26 07:26:13,305 DEBUG RFM2Pi 53 Values : [0, 0, 0, 0, 256.63, 300, 300, 300, 300, 300, 300, 2]
2017-10-26 07:26:13,306 DEBUG RFM2Pi 53 RSSI : -28
2017-10-26 07:26:13,308 DEBUG RFM2Pi 53 Sent to channel(start)’ : ToEmonCMS
2017-10-26 07:26:13,309 DEBUG RFM2Pi 53 Sent to channel(end)’ : ToEmonCMS
2017-10-26 07:26:13,590 DEBUG MQTT Publishing: emon/emontx3/power1 0
2017-10-26 07:26:13,593 DEBUG MQTT Publishing: emon/emontx3/power2 0
2017-10-26 07:26:13,595 DEBUG MQTT Publishing: emon/emontx3/power3 0
2017-10-26 07:26:13,598 DEBUG MQTT Publishing: emon/emontx3/power4 0
2017-10-26 07:26:13,600 DEBUG MQTT Publishing: emon/emontx3/vrms 256.63
2017-10-26 07:26:13,602 DEBUG MQTT Publishing: emon/emontx3/temp1 300
2017-10-26 07:26:13,604 DEBUG MQTT Publishing: emon/emontx3/temp2 300
2017-10-26 07:26:13,606 DEBUG MQTT Publishing: emon/emontx3/temp3 300
2017-10-26 07:26:13,608 DEBUG MQTT Publishing: emon/emontx3/temp4 300
2017-10-26 07:26:13,611 DEBUG MQTT Publishing: emon/emontx3/temp5 300
2017-10-26 07:26:13,613 DEBUG MQTT Publishing: emon/emontx3/temp6 300
2017-10-26 07:26:13,616 DEBUG MQTT Publishing: emon/emontx3/pulse 2
2017-10-26 07:26:13,618 INFO MQTT Publishing: emon/emontx3/rssi -28
2017-10-26 07:26:13,620 INFO MQTT Publishing: emonhub/rx/8/values 0,0,0,0,256.63,300,300,300,300,300,300,2
2017-10-26 07:26:13,622 INFO MQTT Publishing: emonhub/rx/8/rssi -28
What am I doing wrong ?
