Hi all :
I am new to EmonTX and I am an average user of Arduinos. I have ordered an EmonTx shield in order to setup my installation and an SD card to display data on a Raspberry and a radio module RFM69Pi 433Mhz.
My setup will use 2 CTs, will provide power diversion to a water heater and should display on emoncms. Single phase EU version.Basic Arduino UNO.
I have a few issues :
Which software version is the right one to use ? I have been reading lots of docs and visiting many github pages but at the end I am just totally confused.
I have opened in Arduino what I believe is the version 3.4 of Emontx. Then tried to fight with libraries and some issues. It compiles almost fine, the only thing it does not like is the line
if (UNO) wdt_reset(); in the file emontx_lib.
it replies :
In function ‘void emontx_sleep(int)’:
emontx_lib:12:11: error: ‘UNO’ was not declared in this scope
I could not figure what is wrong with that. something missing or a library in the wrong place ?
If I delete the line, everything is fine though.
- Then, for the power diverter. I understand the principle but the trouble is first to find where to connect the static relay to the shield. not clearly mentioned, although I could find this one later by going back to schematics.
Sorry for posting many issues at once. Hope for some of you this is more clear. Thanks for reply.
