I have a EmonTX setup and working for over a year. At about 4am yesterday morning it stopped working. The red LED is blinking every 10 seconds or so, to me it look the same as it always has.
I have restarted both the EmonTX and the EmonPI it is connected to, by removing power and pressing the reset button (reset button on TX only). I have also run a full update to the EmonPI without success. (it did not need any updates)
I have looked at a number of topics here and I can not find anything other then look at the emonhub log in debug mode. (extract below) I can see a warning but am unsure what to do next.
At presant the feeds and inputs are red and feeds not updated for 29 hours
2022-01-27 09:20:19,323 INFO MainThread Logging level set to DEBUG
2022-01-27 09:20:19,323 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2022-01-27 09:20:19,326 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2022-01-27 09:20:21,330 WARNING MainThread Device communication error - check settings
2022-01-27 09:20:21,331 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2022-01-27 09:20:22,334 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2022-01-27 09:20:23,336 INFO MainThread Setting RFM2Pi group: 210 (210g)
2022-01-27 09:20:24,338 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2022-01-27 09:20:25,341 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2022-01-27 09:20:26,343 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2022-01-27 09:20:26,344 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2022-01-27 09:20:26,346 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2022-01-27 09:20:26,352 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2022-01-27 09:20:26,353 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2022-01-27 09:20:26,354 INFO MainThread Setting MQTT node_format_enable: 1
2022-01-27 09:20:26,355 INFO MainThread Setting MQTT nodevar_format_enable: 1
2022-01-27 09:20:26,356 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2022-01-27 09:20:26,357 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2022-01-27 09:20:26,360 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2022-01-27 09:20:26,361 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2022-01-27 09:20:26,362 WARNING MainThread Setting emoncmsorg apikey: obscured
Tom
[edit by Mod]
For future reference, when posting code or bash output, please put in 3 ‘backticks’ (found at the top left of the keyboard normally) on a line on their own, then the code, then 3 more backticks on a line following the code.
code
If it is something like php you can add a language identifier that after the first 3 backticks so ```php
