Here is a bit from the emonhub taken today. Next time it takes a walk I’ll post up another.
2017-06-02 09:17:03,931 DEBUG RFM2Pi 370919 NEW FRAME : OK 10 127 11 4 12 25 4 205 3 26 47 0 0 0 0 0 0 0 0 0 0 0 0 1 0 (-59)
2017-06-02 09:17:03,935 DEBUG RFM2Pi 370919 Timestamp : 1496413023.93
2017-06-02 09:17:03,936 DEBUG RFM2Pi 370919 From Node : 10
2017-06-02 09:17:03,937 DEBUG RFM2Pi 370919 Values : [2943, 3076, 1049, 973, 120.58, 0, 0, 0, 0, 0, 0, 1]
2017-06-02 09:17:03,938 DEBUG RFM2Pi 370919 RSSI : -59
2017-06-02 09:17:03,938 DEBUG RFM2Pi 370919 Sent to channel(start)' : ToEmonCMS
2017-06-02 09:17:03,939 INFO RFM2Pi Publishing: emonhub/rx/10/values 2943,3076,1049,973,120.58,0,0,0,0,0,0,1
2017-06-02 09:17:03,941 INFO RFM2Pi Publishing: emonhub/rx/10/rssi -59
2017-06-02 09:17:03,944 DEBUG RFM2Pi 370919 adding frame to buffer => [1496413023.931317, 10, 2943, 3076, 1049, 973, 120.58, 0, 0, 0, 0, 0, 0, 1, -59]
2017-06-02 09:17:03,945 DEBUG RFM2Pi 370919 Sent to channel(end)' : ToEmonCMS
2017-06-02 09:17:04,775 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 191 122 207 250 239 61 57 247 219 55 255 193 213 222 169 104 95 131 235 30 255 (-96)
2017-06-02 09:17:06,223 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 21 0 0 28 2 206 0 0 245 0 156 (-62)
2017-06-02 09:17:20,793 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 185 210 191 219 166 247 85 83 170 243 231 217 245 115 251 63 214 172 219 199 96 (-89)
2017-06-02 09:17:22,413 DEBUG RFM2Pi 370920 NEW FRAME : OK 10 160 7 217 7 22 4 174 3 24 47 0 0 0 0 0 0 0 0 0 0 0 0 1 0 (-55)
2017-06-02 09:17:22,417 DEBUG RFM2Pi 370920 Timestamp : 1496413042.41
2017-06-02 09:17:22,417 DEBUG RFM2Pi 370920 From Node : 10
2017-06-02 09:17:22,418 DEBUG RFM2Pi 370920 Values : [1952, 2009, 1046, 942, 120.56, 0, 0, 0, 0, 0, 0, 1]
2017-06-02 09:17:22,419 DEBUG RFM2Pi 370920 RSSI : -55
2017-06-02 09:17:22,420 DEBUG RFM2Pi 370920 Sent to channel(start)' : ToEmonCMS
2017-06-02 09:17:22,421 INFO RFM2Pi Publishing: emonhub/rx/10/values 1952,2009,1046,942,120.56,0,0,0,0,0,0,1
2017-06-02 09:17:22,423 INFO RFM2Pi Publishing: emonhub/rx/10/rssi -55
2017-06-02 09:17:22,425 DEBUG RFM2Pi 370920 adding frame to buffer => [1496413042.412646, 10, 1952, 2009, 1046, 942, 120.56, 0, 0, 0, 0, 0, 0, 1, -55]
2017-06-02 09:17:22,426 DEBUG RFM2Pi 370920 Sent to channel(end)' : ToEmonCMS
2017-06-02 09:17:23,040 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 48 196 169 58 148 127 243 223 184 231 253 254 231 218 63 239 175 238 85 88 55 (-92)
2017-06-02 09:17:28,264 DEBUG RFM2Pi 370921 NEW FRAME : OK 20 23 0 122 1 254 0 0 0 (-56)
2017-06-02 09:17:28,267 DEBUG RFM2Pi 370921 Timestamp : 1496413048.26
2017-06-02 09:17:28,268 DEBUG RFM2Pi 370921 From Node : 20
2017-06-02 09:17:28,269 DEBUG RFM2Pi 370921 Values : [2.3000000000000003, 37.800000000000004, 25.400000000000002, 0]
2017-06-02 09:17:28,270 DEBUG RFM2Pi 370921 RSSI : -56
2017-06-02 09:17:28,271 DEBUG RFM2Pi 370921 Sent to channel(start)' : ToEmonCMS
2017-06-02 09:17:28,272 INFO RFM2Pi Publishing: emonhub/rx/20/values 2.3,37.8,25.4,0
2017-06-02 09:17:28,274 INFO RFM2Pi Publishing: emonhub/rx/20/rssi -56
2017-06-02 09:17:28,276 DEBUG RFM2Pi 370921 adding frame to buffer => [1496413048.264297, 20, 2.3000000000000003, 37.800000000000004, 25.400000000000002, 0, -56]
2017-06-02 09:17:28,277 DEBUG RFM2Pi 370921 Sent to channel(end)' : ToEmonCMS
2017-06-02 09:17:28,497 DEBUG RFM2Pi 370922 NEW FRAME : OK 10 115 11 219 12 17 4 173 3 2 47 0 0 0 0 0 0 0 0 0 0 0 0 1 0 (-55)
2017-06-02 09:17:28,501 DEBUG RFM2Pi 370922 Timestamp : 1496413048.5
2017-06-02 09:17:28,502 DEBUG RFM2Pi 370922 From Node : 10
2017-06-02 09:17:28,503 DEBUG RFM2Pi 370922 Values : [2931, 3291, 1041, 941, 120.34, 0, 0, 0, 0, 0, 0, 1]
2017-06-02 09:17:28,503 DEBUG RFM2Pi 370922 RSSI : -55
2017-06-02 09:17:28,504 DEBUG RFM2Pi 370922 Sent to channel(start)' : ToEmonCMS
2017-06-02 09:17:28,505 INFO RFM2Pi Publishing: emonhub/rx/10/values 2931,3291,1041,941,120.34,0,0,0,0,0,0,1
2017-06-02 09:17:28,507 INFO RFM2Pi Publishing: emonhub/rx/10/rssi -55
2017-06-02 09:17:28,510 DEBUG RFM2Pi 370922 adding frame to buffer => [1496413048.497246, 10, 2931, 3291, 1041, 941, 120.34, 0, 0, 0, 0, 0, 0, 1, -55]
2017-06-02 09:17:28,511 DEBUG RFM2Pi 370922 Sent to channel(end)' : ToEmonCMS
2017-06-02 09:17:31,071 INFO emoncmsorg sending: http://*.*.*.*/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1496413023.931317,10,2943,3076,1049,973,120.58,0,0,0,0,0,0,1,-59],[1496413042.412646,10,1952,2009,1046,942,120.56,0,0,0,0,0,0,1,-55],[1496413048.264297,20,2.3000000000000003,37.800000000000004,25.400000000000002,0,-56],[1496413048.497246,10,2931,3291,1041,941,120.34,0,0,0,0,0,0,1,-55]]&sentat=1496413051
2017-06-02 09:17:31,193 DEBUG emoncmsorg acknowledged receipt with 'ok' from http://*.*.*.*
2017-06-02 09:17:31,194 INFO emoncmsorg sending: http://*.*.*.*/myip/set.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y
2017-06-02 09:17:34,662 DEBUG RFM2Pi 370923 NEW FRAME : OK 10 184 7 27 9 37 4 187 3 27 47 0 0 0 0 0 0 0 0 0 0 0 0 1 0 (-54)
2017-06-02 09:17:34,665 DEBUG RFM2Pi 370923 Timestamp : 1496413054.66
2017-06-02 09:17:34,666 DEBUG RFM2Pi 370923 From Node : 10
2017-06-02 09:17:34,667 DEBUG RFM2Pi 370923 Values : [1976, 2331, 1061, 955, 120.59, 0, 0, 0, 0, 0, 0, 1]
2017-06-02 09:17:34,668 DEBUG RFM2Pi 370923 RSSI : -54
2017-06-02 09:17:34,669 DEBUG RFM2Pi 370923 Sent to channel(start)' : ToEmonCMS
2017-06-02 09:17:34,670 INFO RFM2Pi Publishing: emonhub/rx/10/values 1976,2331,1061,955,120.59,0,0,0,0,0,0,1
2017-06-02 09:17:34,672 INFO RFM2Pi Publishing: emonhub/rx/10/rssi -54
2017-06-02 09:17:34,674 DEBUG RFM2Pi 370923 adding frame to buffer => [1496413054.661655, 10, 1976, 2331, 1061, 955, 120.59, 0, 0, 0, 0, 0, 0, 1, -54]
2017-06-02 09:17:34,675 DEBUG RFM2Pi 370923 Sent to channel(end)' : ToEmonCMS
2017-06-02 09:17:35,991 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 62 217 225 94 222 253 111 189 179 239 189 95 247 118 30 119 171 255 122 47 249 (-91)
2017-06-02 09:17:39,645 DEBUG RFM2Pi 370924 NEW FRAME : OK 21 0 0 28 2 205 0 206 0 246 0 (-60)
2017-06-02 09:17:39,648 DEBUG RFM2Pi 370924 Timestamp : 1496413059.65
2017-06-02 09:17:39,649 DEBUG RFM2Pi 370924 From Node : 21
2017-06-02 09:17:39,650 DEBUG RFM2Pi 370924 Values : [0, 54, 20.5, 20.6, 24.6]
2017-06-02 09:17:39,650 DEBUG RFM2Pi 370924 RSSI : -60
2017-06-02 09:17:39,651 DEBUG RFM2Pi 370924 Sent to channel(start)' : ToEmonCMS
2017-06-02 09:17:39,652 INFO RFM2Pi Publishing: emonhub/rx/21/values 0,54,20.5,20.6,24.6
2017-06-02 09:17:39,654 INFO RFM2Pi Publishing: emonhub/rx/21/rssi -60
2017-06-02 09:17:39,656 DEBUG RFM2Pi 370924 adding frame to buffer => [1496413059.645058, 21, 0, 54, 20.5, 20.6, 24.6, -60]
2017-06-02 09:17:39,657 DEBUG RFM2Pi 370924 Sent to channel(end)' : ToEmonCMS
2017-06-02 09:17:40,877 DEBUG RFM2Pi 370925 NEW FRAME : OK 10 164 7 215 7 25 4 217 3 26 47 0 0 0 0 0 0 0 0 0 0 0 0 1 0 (-54)
2017-06-02 09:17:40,881 DEBUG RFM2Pi 370925 Timestamp : 1496413060.88
2017-06-02 09:17:40,882 DEBUG RFM2Pi 370925 From Node : 10
2017-06-02 09:17:40,883 DEBUG RFM2Pi 370925 Values : [1956, 2007, 1049, 985, 120.58, 0, 0, 0, 0, 0, 0, 1]
2017-06-02 09:17:40,883 DEBUG RFM2Pi 370925 RSSI : -54
2017-06-02 09:17:40,884 DEBUG RFM2Pi 370925 Sent to channel(start)' : ToEmonCMS
2017-06-02 09:17:40,885 INFO RFM2Pi Publishing: emonhub/rx/10/values 1956,2007,1049,985,120.58,0,0,0,0,0,0,1
2017-06-02 09:17:40,887 INFO RFM2Pi Publishing: emonhub/rx/10/rssi -54
2017-06-02 09:17:40,890 DEBUG RFM2Pi 370925 adding frame to buffer => [1496413060.87723, 10, 1956, 2007, 1049, 985, 120.58, 0, 0, 0, 0, 0, 0, 1, -54]
2017-06-02 09:17:40,891 DEBUG RFM2Pi 370925 Sent to channel(end)' : ToEmonCMS
2017-06-02 09:17:46,634 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 191 66 44 135 214 123 113 125 255 204 114 186 239 191 42 135 125 98 118 144 196 (-96)
2017-06-02 09:17:46,956 DEBUG RFM2Pi 370926 NEW FRAME : OK 10 153 7 181 9 16 4 196 3 40 47 0 0 0 0 0 0 0 0 0 0 0 0 1 0 (-55)
2017-06-02 09:17:46,960 DEBUG RFM2Pi 370926 Timestamp : 1496413066.96
2017-06-02 09:17:46,961 DEBUG RFM2Pi 370926 From Node : 10
2017-06-02 09:17:46,962 DEBUG RFM2Pi 370926 Values : [1945, 2485, 1040, 964, 120.72, 0, 0, 0, 0, 0, 0, 1]
2017-06-02 09:17:46,963 DEBUG RFM2Pi 370926 RSSI : -55
2017-06-02 09:17:46,963 DEBUG RFM2Pi 370926 Sent to channel(start)' : ToEmonCMS
2017-06-02 09:17:46,965 INFO RFM2Pi Publishing: emonhub/rx/10/values 1945,2485,1040,964,120.72,0,0,0,0,0,0,1
2017-06-02 09:17:46,967 INFO RFM2Pi Publishing: emonhub/rx/10/rssi -55
2017-06-02 09:17:46,969 DEBUG RFM2Pi 370926 adding frame to buffer => [1496413066.956372, 10, 1945, 2485, 1040, 964, 120.72, 0, 0, 0, 0, 0, 0, 1, -55]
2017-06-02 09:17:46,970 DEBUG RFM2Pi 370926 Sent to channel(end)' : ToEmonCMS
2017-06-02 09:17:53,185 DEBUG RFM2Pi 370927 NEW FRAME : OK 10 96 11 82 13 21 4 198 3 14 47 0 0 0 0 0 0 0 0 0 0 0 0 1 0 (-55)
2017-06-02 09:17:53,189 DEBUG RFM2Pi 370927 Timestamp : 1496413073.19
2017-06-02 09:17:53,190 DEBUG RFM2Pi 370927 From Node : 10
2017-06-02 09:17:53,191 DEBUG RFM2Pi 370927 Values : [2912, 3410, 1045, 966, 120.46000000000001, 0, 0, 0, 0, 0, 0, 1]
2017-06-02 09:17:53,191 DEBUG RFM2Pi 370927 RSSI : -55
2017-06-02 09:17:53,192 DEBUG RFM2Pi 370927 Sent to channel(start)' : ToEmonCMS
2017-06-02 09:17:53,193 INFO RFM2Pi Publishing: emonhub/rx/10/values 2912,3410,1045,966,120.46,0,0,0,0,0,0,1
2017-06-02 09:17:53,196 INFO RFM2Pi Publishing: emonhub/rx/10/rssi -55
2017-06-02 09:17:53,198 DEBUG RFM2Pi 370927 adding frame to buffer => [1496413073.185063, 10, 2912, 3410, 1045, 966, 120.46000000000001, 0, 0, 0, 0, 0, 0, 1, -55]
2017-06-02 09:17:53,199 DEBUG RFM2Pi 370927 Sent to channel(end)' : ToEmonCMS
2017-06-02 09:17:56,151 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 187 241 199 95 111 157 67 199 188 93 124 6 184 253 195 187 179 191 254 159 255 (-94)
2017-06-02 09:17:59,271 DEBUG RFM2Pi 370928 NEW FRAME : OK 10 163 7 219 7 21 4 193 3 37 47 0 0 0 0 0 0 0 0 0 0 0 0 1 0 (-59)
2017-06-02 09:17:59,275 DEBUG RFM2Pi 370928 Timestamp : 1496413079.27
2017-06-02 09:17:59,276 DEBUG RFM2Pi 370928 From Node : 10
2017-06-02 09:17:59,276 DEBUG RFM2Pi 370928 Values : [1955, 2011, 1045, 961, 120.69, 0, 0, 0, 0, 0, 0, 1]
2017-06-02 09:17:59,277 DEBUG RFM2Pi 370928 RSSI : -59
2017-06-02 09:17:59,278 DEBUG RFM2Pi 370928 Sent to channel(start)' : ToEmonCMS
2017-06-02 09:17:59,279 INFO RFM2Pi Publishing: emonhub/rx/10/values 1955,2011,1045,961,120.69,0,0,0,0,0,0,1
2017-06-02 09:17:59,281 INFO RFM2Pi Publishing: emonhub/rx/10/rssi -59
2017-06-02 09:17:59,283 DEBUG RFM2Pi 370928 adding frame to buffer => [1496413079.270912, 10, 1955, 2011, 1045, 961, 120.69, 0, 0, 0, 0, 0, 0, 1, -59]
2017-06-02 09:17:59,284 DEBUG RFM2Pi 370928 Sent to channel(end)' : ToEmonCMS
2017-06-02 09:18:01,136 INFO emoncmsorg sending: http://*.*.*.*/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1496413054.661655,10,1976,2331,1061,955,120.59,0,0,0,0,0,0,1,-54],[1496413059.645058,21,0,54,20.5,20.6,24.6,-60],[1496413060.87723,10,1956,2007,1049,985,120.58,0,0,0,0,0,0,1,-54],[1496413066.956372,10,1945,2485,1040,964,120.72,0,0,0,0,0,0,1,-55],[1496413073.185063,10,2912,3410,1045,966,120.46000000000001,0,0,0,0,0,0,1,-55],[1496413079.270912,10,1955,2011,1045,961,120.69,0,0,0,0,0,0,1,-59]]&sentat=1496413081
