emonTx V3 Fritzing?
Continuing the discussion from Using the EmonTx v3 with the ESP8266 Huzzah WIFI module:
Hi @jeremypoulter, I noticed in the above thread you posted a nice graphic of the emonTx V3 with an ESP module, it looks very much like a Fritzing graphic, is this the case? If so could you share the design for community use?
Thanks a lot :slight_smile:
Indeed it is a Fritzing graphic, it was made using Adafruit’s version of the eagle2fritzing tool; GitHub - adafruit/eagle2fritzing: Converters from EAGLE to Fritzing file format, I certainly intend to make them available I was just going to try to fill in a few more of the components first :wink: and also try and figure out why some of the silk screen is missing, but getting there.
Awesome! Thanks a lot, it’s really nice. I will put it on the emonTx
hardware wiki and hardware github. Would also be nice to make one for the
emonpi pcb.
  • sent from my mobile device
Stay tuned, I think once I have this done this one additional boards should get easier.
