Somewhat randomly a few weeks ago my EmonTX 3.4 decided to stop working after a number of years of working, and is now in a reboot cycle when initialising the radio module, have flashed to EmonTX3CM v2.3 in the hope that this would solve (e.g. software problem) with no success
0:59:57.934 -> emonTx V3.4 EmonLibCM Continuous Monitoring V2.30
20:59:57.934 -> OpenEnergyMonitor.org
20:59:57.934 -> Loaded EEPROM config
20:59:57.934 -> Settings:
20:59:57.934 -> Group 210, Node 15, Band 433 MHz
20:59:57.934 ->
20:59:57.934 -> Calibration:
20:59:57.934 -> vCal = 268.97
20:59:57.934 -> assumedV = 240.00
20:59:57.934 -> i1Cal = 90.90
20:59:57.934 -> i1Lead = 4.20
20:59:57.934 -> i2Cal = 90.90
20:59:57.934 -> i2Lead = 4.20
20:59:57.934 -> i3Cal = 90.90
20:59:57.934 -> i3Lead = 4.20
20:59:57.934 -> i4Cal = 16.67
20:59:57.934 -> i4Lead = 6.00
20:59:57.934 -> datalog = 9.96
20:59:57.934 -> pulses = 1
20:59:57.934 -> pulse period = 100
20:59:57.934 -> temp_enable = 1
20:59:57.970 -> RF on
20:59:57.970 -> RFM69CW only Node: 15 Freq: 433MHz Group: 210
20:59:57.970 ->
20:59:57.970 -> POST.....wait 10s
20:59:57.970 -> '+++' then [Enter] for config mode
21:00:16.711 -> emonTx V3.4 EmonLibCM Continuous Monitoring V2.30
21:00:16.711 -> OpenEnergyMonitor.org
21:00:16.711 -> Loaded EEPROM config
21:00:16.711 -> Settings:
21:00:16.711 -> Group 210, Node 15, Band 433 MHz
21:00:16.711 ->
21:00:16.711 -> Calibration:
21:00:16.711 -> vCal = 268.97
21:00:16.711 -> assumedV = 240.00
21:00:16.711 -> i1Cal = 90.90
21:00:16.711 -> i1Lead = 4.20
21:00:16.711 -> i2Cal = 90.90
21:00:16.711 -> i2Lead = 4.20
21:00:16.711 -> i3Cal = 90.90
21:00:16.711 -> i3Lead = 4.20
21:00:16.711 -> i4Cal = 16.67
21:00:16.711 -> i4Lead = 6.00
21:00:16.711 -> datalog = 9.96
21:00:16.744 -> pulses = 1
21:00:16.744 -> pulse period = 100
21:00:16.744 -> temp_enable = 1
21:00:16.744 -> RF on
21:00:16.744 -> RFM69CW only Node: 15 Freq: 433MHz Group: 210
21:00:16.744 ->
21:00:16.744 -> POST.....wait 10s
21:00:16.744 -> '+++' then [Enter] for config mode
Disabling the radio using x0, allows the TX to start logging data correctly, so I’m thinking that it’s an issue with the radio. So question to you kind and knowledgeable folks, is this a blown/failed radio module (potential dry-joint etc) - or potentially solvable in software?
Thanks,
Mike
