Hi all,
I’ve just finished building an emonTx v2 and I have an issue with the data being posted to Emoncms. The emonTx is visible in the inputs page but all I see is the rssi input. In the logs I can see that the data is being received by the RFM12PI:
2017-04-01 21:01:03,828 DEBUG RFM2Pi 67342 NEW FRAME : 10 147 2 0 0 0 0 34 13
2017-04-01 21:01:03,836 DEBUG RFM2Pi 67342 Timestamp : 1491080463.83
2017-04-01 21:01:03,838 DEBUG RFM2Pi 67342 From Node : 10
2017-04-01 21:01:03,841 DEBUG RFM2Pi 67342 Values : [659, 0, 0, 3362]
2017-04-01 21:01:03,843 DEBUG RFM2Pi 67342 Sent to channel(start)' : ToEmonCMS
2017-04-01 21:01:03,849 INFO RFM2Pi Publishing: emon/emontx1/power1 659
2017-04-01 21:01:03,856 INFO RFM2Pi Publishing: emon/emontx1/power2 0
2017-04-01 21:01:03,888 INFO RFM2Pi Publishing: emon/emontx1/power3 0
2017-04-01 21:01:03,897 INFO RFM2Pi Publishing: emon/emontx1/power4 3362
2017-04-01 21:01:03,902 INFO RFM2Pi Publishing: emon/emontx1/rssi 0
2017-04-01 21:01:03,908 INFO RFM2Pi Publishing: emonhub/rx/10/values 659,0,0,3362
2017-04-01 21:01:03,914 INFO RFM2Pi Publishing: emonhub/rx/10/rssi 0
2017-04-01 21:01:03,921 DEBUG RFM2Pi 67342 adding frame to buffer => [1491080463.828155, 10, 659, 0, 0, 3362]
2017-04-01 21:01:03,924 DEBUG RFM2Pi 67342 Sent to channel(end)' : ToEmonCMS
I also have an emonTh v3 which is working successfully. I’m running Emoncms 9.8.0 locally with an RFM12PI and the emonTx uses an RFM69.
Here is the config for the emonTx:
[[10]]
nodename = emontx1
[[[rx]]]
datacode = h
units =W,W,W,W,V,C,C,C,C,C,C,p
Any help greatly appreciated!
Mark
