I am trying to get emonpi on my raspberry pi using ( emonSD-26Oct17.img updated to low-write 9.8.31 | 2018.06.21) to read my emontx shield + Leonardo using (emonTxFirmware/emonTxV3_DirectSerial.ino at master · openenergymonitor/emonTxFirmware · GitHub ) via usb cable.
I followed a lot of https://community.openenergymonitor.org/t/serial-direct-connection-between-pi-and-emontx-shield/2611/63 which helped greatly
Using this script on the pi
#!/usr/bin/python
import serial, string
output = " "
ser = serial.Serial('/dev/ttyACM0', 9600, 8, 'N', 1, timeout=1)
while True:
print "----"
while output != "":
output = ser.readline()
print output
output = " "
I get a reading of
6 579.17 782.01 878.11 276.54 41.62
6 584.23 749.91 878.98 273.30 41.79
6 585.42 747.07 885.86 269.33 41.84
6 607.19 748.19 889.32 269.67 42.39
6 582.72 750.78 1000.26 278.32 41.73
6 585.07 747.13 891.93 268.31 41.83
on Putty
Therefore I know that emonpi is receiving the info from the arduino
next I tried Emonhub.conf
[interfacers]
[[RFM2Pi]]
Type = EmonHubSerialInterfacer
[[[init_settings]]]
com_port = /dev/ttyACM0
com_baud = 9600
[[[runtimesettings]]]
# group = 210
# frequency = 433
# baseid = 15
If I use [[Serial]] , emonhub doesn’t show starting like Lazlo mentioned in the above linked forum
My log says
2018-07-24 15:40:38,279 DEBUG MainThread SIGINT received.
2018-07-24 15:40:38,485 INFO MainThread Exiting hub...
2018-07-24 15:40:38,637 INFO MainThread Exit completed
2018-07-24 15:41:04,617 INFO MainThread EmonHub emonHub emon-pi variant v2.1.1
2018-07-24 15:41:04,640 INFO MainThread Opening hub...
2018-07-24 15:41:04,643 INFO MainThread Logging level set to DEBUG
2018-07-24 15:41:04,688 INFO MainThread Creating EmonHubSerialInterfacer 'RFM2Pi'
2018-07-24 15:41:04,749 DEBUG MainThread Opening serial port: /dev/ttyACM0 @ 9600 bits/s
2018-07-24 15:41:04,782 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2018-07-24 15:41:04,823 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2018-07-24 15:41:04,841 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2018-07-24 15:41:04,844 INFO MainThread Setting MQTT nodevar_format_enable: 1
2018-07-24 15:41:04,900 INFO MainThread Setting MQTT node_format_enable: 1
2018-07-24 15:41:04,903 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2018-07-24 15:41:04,950 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2018-07-24 15:41:04,956 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2018-07-24 15:41:04,958 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2018-07-24 15:41:05,020 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2018-07-24 15:41:05,023 INFO MainThread Setting emoncmsorg senddata: 1
2018-07-24 15:41:05,025 INFO MainThread Setting emoncmsorg apikey: set
2018-07-24 15:41:05,028 INFO MainThread Setting emoncmsorg sendstatus: 1
Any ideas?
