Hello all, I’m new to the community, but been following the project for a long time! Now finally I’m gonna enter this world!
I would like to have one EmonTx monitoring the power in my house, and posting it to my local server. This is my main question! At the moment I already have the emoncms running on my home server, and I would like to keep it that way, my server is by far more reliable than a raspberry pi SD card! So my question is, what is the best approach to get the data from the emontx to the emoncms on my server? Can I use the esp to do it by wirless? Or do I need a emonbase with the raspberry pi? Can the emonbase post to my local server?
When using the EmonSerialTx3eInterfacer in emonHub to connect to the emonTx using the output designed solely for the emonESP you will need to tell it what node ID you would like it to use by using the “nodeoffset” setting in emonhub.conf eg if using the default node id of 8.
So, from what I understand, for my setup, a esp is more than enough! I will be having a emontx monitoring my main devices and the house total consumption! I don’t know if I my need a second emontx, but from what I understand, that would not be a problem! They will be posting directly to my mqtt server and my emoncms instance! Correct?
That is correct. All you need to do is ensure they use different NodeIDs.
I think the part above about the EmonSerialTx3eInterfacer might be misleading, as I think that’s only when you are using the direct serial interface, not sending the data by WiFi / Ethernet, as you will be doing.
