I have a NanodeRF* and was thinking of getting a emonTx Shield to use with it, and then I noticed the shield has a 2x3 connector in the middle for ISP pins but the Nanode does not have ISP pins in the same place as other Arduinos.
Questions:
The Nanode is listed as being compatible - does this mean the ISP connector is optional?
Why is the ISP connector needed? From what I can tell, it looks like all the pins in the ISP cluster are already connected via the pins on the edges of the board.
Thanks for your help!
a kit that was sitting in a box for 10 years that I finally assembled today
The ISP connector isn’t normally needed. As I understand it, it’s for the advanced Atmel programmer that allows in-circuit debugging and stuff like that - not the one from The Shop. You just need the FTDI connector and the ‘Shop’ programmer.
[Edit]
My NanodeRF has a right-angled FTDI header, so a Shield won’t mate with it - the a.c. connector is in the way. So I can’t prove that NanodeRF + emonTx Shield will work, but I don’t know of a reason why it won’t.
