Hi all,
I have been trying to get some of my old emonTX kit back working again for a couple of projects. The first is some automation on our tumble dryer. The dryer is connected to a homemade heat recovery unit, which needs to be activated when the dryer is running. So my plan was to put a CT on the dryer power supply, and use this to switch the fans on the heat recovery.
As a bonus, I thought I could use one of my emonTX v2 units to monitor the dryer energy use as well (hopefully to demonstrate that the heat recovery is working!).
So I wrote a modified version of the CT123 sketch. As well as the monitoring, the sketch a) turns on the heat recovery (DryerPin digital output to other controller) and also controls a servo which opens/closes a damper in the duct.
Code is below.
When run the serial monitor, I initially get numbers I expect (around 2.6kW dryer power), but then the numbers start to become garbled, with strange characters coming in. I have checked baud rates and the usual suspects for this.
The serial seems to work ok itself- I can run simple “hello world” sketches no problem.
I’m having the issue with more than one Arduino-based board.
The common theme seems to be sketches which use the emontx library as far as I can tell. I have another sketch which is similar, but simply collects temperatures which I want to monitor on serial (as well as sending to emoncms). I get the same issue- random characters mixed with numbers and text.
Any thoughts on what could be going wrong? Is it the UART programmer? Is it to do with emontx library?
Any thoughts much appreciated!
Chris
EmonTx CT123 example
An example sketch for the emontx module for
CT only electricity monitoring.
Part of the openenergymonitor.org project
Licence: GNU GPL V3
Authors: Glyn Hudson, Trystan Lea
Builds upon JeeLabs RF12 library and Arduino
emonTx documentation: http://openenergymonitor.org/emon/modules/emontx/
emonTx firmware code explination: http://openenergymonitor.org/emon/modules/emontx/firmware
emonTx calibration instructions: http://openenergymonitor.org/emon/modules/emontx/firmware/calibration
THIS SKETCH REQUIRES:
Libraries in the standard arduino libraries folder:
- JeeLib https://github.com/jcw/jeelib
- EmonLib https://github.com/openenergymonitor/EmonLib.git
Other files in project directory (should appear in the arduino tabs above)
- emontx_lib.ino
/*Recommended node ID allocation
-ID- -Node Type-
0 - Special allocation in JeeLib RFM12 driver - reserved for OOK use
1-4 - Control nodes
5-10 - Energy monitoring nodes
11-14 --Un-assigned --
15-16 - Base Station & logging nodes
17-30 - Environmental sensing nodes (temperature humidity etc.)
31 - Special allocation in JeeLib RFM12 driver - Node31 can communicate with nodes on any network group
#define FILTERSETTLETIME 5000 // Time (ms) to allow the filters to settle before sending data
const int CT1 = 1;
const int CT2 = 0; // Set to 0 to disable CT channel 2
const int CT3 = 0; // Set to 0 to disable CT channel 3
#define RF69_COMPAT 0 // SET TO 1 IF RFM69
#define RF_freq RF12_868MHZ // Frequency of RF12B module can be RF12_433MHZ, RF12_868MHZ or RF12_915MHZ. You should use the one matching the module you have.
const int nodeID = 10; // emonTx RFM12B node ID
const int networkGroup = 210; // emonTx RFM12B wireless network group - needs to be same as emonBase and emonGLCD
const int UNO = 1; // Set to 0 if your not using the UNO bootloader (i.e using Duemilanove) - All Atmega's shipped from OpenEnergyMonitor come with Arduino Uno bootloader
#include <avr/wdt.h>
#define RF69_COMPAT 0 // set to 1 to use RFM69CW
#include <JeeLib.h> // make sure V12 (latest) is used if using RFM69CW
ISR(WDT_vect) { Sleepy::watchdogEvent(); } // Attached JeeLib sleep function to Atmega328 watchdog -enables MCU to be put into sleep mode inbetween readings to reduce power consumption
#include "EmonLib.h"
EnergyMonitor ct1,ct2,ct3; // Create instances for each CT channel
typedef struct { int power1, power2, power3, battery; } PayloadTX; // create structure - a neat way of packaging data for RF comms
PayloadTX emontx;
const int LEDpin = 9; // On-board emonTx LED
boolean settled = false;
#include <Servo.h>
Servo servoMain; // Define our Servo
int Pos=0;
boolean Signal;
const int DryerPin=6; //Output pin to signal to main Arduino for dryer operation.
const int Dryer_Threshold=100; //Power threshold (to be tested. Needs to be when dryer on, but not heating or motor on)
void setup()
servoMain.attach(10,2000,12000);
pinMode(3,INPUT);
digitalWrite(LEDpin,HIGH);
servoMain.write(Pos);//Start with damper closed
delay(15);
pinMode(DryerPin, OUTPUT);
digitalWrite(DryerPin, LOW);
Serial.begin(9600);
Serial.println("emonTX CT123 example");
Serial.println("OpenEnergyMonitor.org");
Serial.print("Node: ");
Serial.print(nodeID);
Serial.print(" Freq: ");
if (RF_freq == RF12_433MHZ) Serial.print("433Mhz");
if (RF_freq == RF12_868MHZ) Serial.print("868Mhz");
if (RF_freq == RF12_915MHZ) Serial.print("915Mhz");
Serial.print(" Network: ");
Serial.println(networkGroup);
if (CT1) ct1.currentTX(1, 111.1); // Setup emonTX CT channel (ADC input, calibration)
if (CT2) ct2.currentTX(2, 111.1); // Calibration factor = CT ratio / burden resistance
if (CT3) ct3.currentTX(3, 111.1); // Calibration factor = (100A / 0.05A) / 33 Ohms
rf12_initialize(nodeID, RF_freq, networkGroup); // initialize RFM12B
rf12_sleep(RF12_SLEEP);
pinMode(LEDpin, OUTPUT); // Setup indicator LED
digitalWrite(LEDpin, HIGH);
if (UNO) wdt_enable(WDTO_8S); // Enable anti crash (restart) watchdog if UNO bootloader is selected. Watchdog does not work with duemilanove bootloader // Restarts emonTx if sketch hangs for more than 8s
void loop()
if (CT1) {
emontx.power1 = ct1.calcIrms(1480) * 240.0; //ct.calcIrms(number of wavelengths sample)*AC RMS voltage
Serial.println(emontx.power1);
delay(1000);
if (CT2) {
emontx.power2 = ct2.calcIrms(1480) * 240.0;
Serial.print(" "); Serial.print(emontx.power2);
if (CT3) {
emontx.power3 = ct3.calcIrms(1480) * 240.0;
Serial.print(" "); Serial.print(emontx.power3);
emontx.battery = ct1.readVcc(); //read emonTx battey (supply voltage)
//CHECK IF DRYER IS RUNNING.
if(emontx.power1<Dryer_Threshold) //If the dryer power consumption is less than 100W, assume it is not operating. This figure could probably be reduced.
servoMain.write(10);//close the damper
digitalWrite(DryerPin,LOW); //Send signal to MVHR to shut down.
else
servoMain.write(180);//Open the damper
digitalWrite(DryerPin,HIGH); //Send signal to MVHR to shut down.
//Serial.print(" "); Serial.print(emontx.battery);
//Serial.println(); delay(100);
// because millis() returns to zero after 50 days !
if (!settled && millis() > FILTERSETTLETIME) settled = true;
if (settled) // send data only after filters have settled
send_rf_data(); // *SEND RF DATA* - see emontx_lib
digitalWrite(LEDpin, HIGH); delay(2); digitalWrite(LEDpin, LOW); // flash LED
emontx_sleep(5); // sleep or delay in seconds - see emontx_lib
Edit - formatted text. BT, Moderator
